ZEX Wet or Dry Kit for 03 Maxima
Old Jun 28, 2004 | 04:08 PM
hct67's Avatar
Sorry to post this here but there is no one in the Nitrous Area of the Org so I thought I would ask people here!!
Whats better and does anyone have any of these kits on there Maxima's. They seem pretty damn good, where you don't need any button to give your Max a boost. Its all automatic as the kit is activated at wide open throttle by a programmable electronic sensor that learns the voltage curve of your TPS sensor
http://www.customenterprise.com/view...3/store/maxima
Old Jun 28, 2004 | 04:20 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
This is going to get moved...
Old Jun 28, 2004 | 04:24 PM
hct67's Avatar
Why
Why will it get moved. Theres no one in the nitrous section of the Org ever to answer this question and also I just wanted everyone to know that CustomMaxima.com is now CustomEnterprise.com with their new designed website to look at.
Old Jun 28, 2004 | 05:28 PM
skandalouz's Avatar
if u have an 03 maxima, there is quite a bit of modification to make the dry kit work.... ur better off going with the wet kit...
Old Jun 28, 2004 | 05:48 PM
irish44j's Avatar
retired moderator
oh, so "Maxima" isn't good enough for CM/CE anymore? b1tches! "Custom Enterprises" sounds like they make bongs or something.....
nitrous = steroids. and nobody is rooting for Barry Bonds.....
Old Jun 28, 2004 | 06:01 PM
WildmanAL's Avatar
Another org member had a big right up about the dry kit. I think it was SR.... I can't remember the guys screen name. If I'm not mistaken it had something to do with the fuel return line... that is, our 5.5 gen maximas don't have one. It took a lot of work for the dry kit to work and he said it may not of even been worth it. I know this didn't help much, but it gives you a heads up on the dry kit and out maximas.
Old Jun 28, 2004 | 09:50 PM
white m3 guy's Avatar
basically the 5.5 gens do not have return fuel lines which really sucks that is one of the reasons why there isnt a supercharger out there for us anyhow, if you use a dry kit you will most likely blow your engine because dry kits require return fuel, so i would recomend buying a wet kit
SmokinMax02
18
Sep 11, 2015 12:25 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Team STILLEN
Aug 10, 2015 04:29 PM
