blehmco brake kit....
Old Jun 30, 2004 | 05:59 AM
panda_1's Avatar
would the relocation calipers fit over the 300zx rotors and work correctly?
Old Jun 30, 2004 | 06:19 AM
UMD_MaxSE's Avatar
Got Bent?
the Z rotors are not big enough... you don't need a relocation bracket if you use Z rotors... the relocation bracket allows you to use the larger 2004 Maxima rotors.
Old Jul 1, 2004 | 05:32 AM
Matt93SE's Avatar
STFU n00b!
The kit is designed specifically to fit the 2004 Max rotor with the 300ZX 30mm caliper, or the OEM 5th gen caliper- whichever you choose. They will ONLY fit that rotor and caliper combination. feel free to shoot me an email if you have any questions on it. tech@mattblehm.com
Old Jul 1, 2004 | 09:50 PM
kwd2kSE's Avatar
I was the first to get Matt's brake kit-with the 300ZX calipers. Actually, I was the test mule for both kits. It's been on the car since January with ZERO problems.
Old Jul 1, 2004 | 11:24 PM
panda_1's Avatar
its time for brakes and its really tight with money, so im looking for the most bang for my buck. i have decided to go with the blehmco relocation kit, but i am ordering everything else seperately. for instance, i am getting the 04 rotors of off jerryrome nissans page because we have the discount. i also have a discount from pepboys, which is where i am getting my greenstuff pads from and i am getting the ss brake lines from goodridge. the approxamite total for all is 430.
Old Jul 1, 2004 | 11:25 PM
panda_1's Avatar
dont mean to be a tight *** or anything, but gotta do what i gotta do.
Old Jul 2, 2004 | 02:33 AM
spirilis's Avatar
Nothing wrong with that... I got my rotors from DAVEB, and pads online from importrp.com (PBR Metal Masters), and the SS brake hoses I already had from last fall from Automax_95 (techna-fit)
Old Jul 3, 2004 | 01:47 AM
panda_1's Avatar
Im Haveing Trouble Finding The Ss Lines, Can Anyone Help?
Old Jul 3, 2004 | 03:04 AM
jnovember's Avatar
SS Lines with Blehmco
I already have SS lines which fit with stock calipers/rotors. Will the existing SS lines fit with blehmco, 2k4 rotors, & stock calipers?
Old Jul 3, 2004 | 05:42 AM
Matt93SE's Avatar
STFU n00b!
If you do the stock caliper relocation kit, the stock (or SS) brake hoses will fit fine..
as for where to find the lines,
http://www.hoerr-racing.com/
www.techna-fit.com
are both suppliers that I've used in the past.
Old Jul 3, 2004 | 10:29 AM
scopium
question.. i read that 300zx rotors are fine with stock calipers and no relocation..
but are the rotors big enough to stop the warpping
and are there any clearance issues...
i'm on a tight budget so..
and whats the benefit of ss brake lines?
Old Jul 3, 2004 | 01:52 PM
UMD_MaxSE's Avatar
Got Bent?
The 300ZX rotors will need to be milled down or else they may not clear the lower control arm on the suspension...
Old Jul 3, 2004 | 03:21 PM
panda_1's Avatar
the ss lines will create a better feeling pedal, by not allowing the stock lines to flex under heavy braking.
Old Jul 4, 2004 | 08:25 AM
VQ30DES's Avatar
How much better are the 300zx brakes? Also you cant use them with the factory 17's correct. Or could i just wheel spacers to create enough offset for the calipers.
Old Jul 4, 2004 | 08:34 AM
Colonel's Avatar
Old Fuddy Duddy
I have a 2K1, and did the full kit. Relocation, SS lines, OEM Ceramic Pads, 04 Rotors and ATE Super Blue Fluid.
They are PHENOMENAL. I did pre and post tests on stock and on the new equipment and was able to whittle down my 60-0 times an average of 15ft. On some of my better stops, I was able to knock of 20 ft. Pedal feel is GREAT (no sogginess at ALL).
You will NOT get the 300Z calipers behind the stock wheels. I am not even sure if you used a really large spacer if it would create enough room. I have Konig Verdicts and it was so close, I ended up needing a 5mm spacers to make sure it fit correctly. If the raised Nissan wording portion was not there, it would have been a perfect fit.
He is how they look on my car
Old Jul 4, 2004 | 02:48 PM
VQ30DES's Avatar
So do you use the 04 max rotors or the 30zx rotors? Is the blehmco brake kit te 300zx brakes?
Old Jul 4, 2004 | 03:00 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Blehmco kit is basically eighter stock calipers or 300ZX calipers relocated to fit over 04 Maxima rotors which are ALOT bigger than the 300ZX or stock Maxima rotors. These are just as big as the Brembo brakes on 350Zs and G35s. Matt also sells special braided lines to fit the 300ZX calipers on the 5th gen and braided steel lines for the stock rear brakes. I belive that Sumitomo 300ZX calipers are better than the Brembos on the 350Z and G- simply cause U can get all kinds of diff brake pads for the 300ZX calipers, and getting a set of pads from AutoZone or Napa for Brembo calipers is going to be a challenge.
Old Jul 4, 2004 | 03:07 PM
kwd2kSE's Avatar
Look at Matt's web site, under the Brakes section.
http://www.mattblehm.com/
You use the '04 Max rotors, NOT the 300ZX rotors. You pick which calipers you want to use, that determines which brackets you get with the kit. Oh, and forget about using the 300ZX calipers under stock 17's. No way unless you want to use at least a 30mm spacer-obviously not!
Mike
Old Jul 5, 2004 | 05:08 AM
VQ30DES's Avatar
How much better is the braking with the kit that uses the stock 5th gen calipers. Does it just reduce the warping of the rotor since it is bigger.
Old Jul 5, 2004 | 09:33 AM
panda_1's Avatar
Yes. It Reduces The Warping And Gives You Better Cooling And Some More Braking Feel, Because Of The Larger Rotors.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
