p0430?...what?
Old Jul 7, 2004 | 04:30 AM
gameover03's Avatar
p0430?...what?
ok boys i got a code read at autozone but the readout is gibberish..n e body can translate what a p0430 is.....
Old Jul 7, 2004 | 05:14 AM
kclmax2k1's Avatar
Catalyst System Efficiency Below Threshold (Bank 2)
Base on the manual:
The ECM monitors the switching frequency ratio of front and rear heated oxygen sensors. A warm-up three way catalyst with high oxygen storage capacity will indicate a low switching frequency of rear heated oxygen sensor. As oxygen storage capacity decreases, the rear heated oxygen sensor switching frequency will increase. When the frequency ratio of front and rear heated oxygen sensors approaches a specified limit value, the warm-up three way catalyst malfunction is diagnosed. Malfunction is detected when warm-up three way catalyst does not operate properly, warm-up three way catalyst does not have enough oxygen storage capacity.
It is like P0420 (bank 1).
Old Jul 7, 2004 | 05:17 AM
gameover03's Avatar
dude thanx for the reply..but that still means gibberish to me...in lamens terms please.....how much is gonna cost and whats broken..?
Old Jul 7, 2004 | 05:34 AM
kclmax2k1's Avatar
You may check this
http://maxima.theowensfamily.com/tsb/NTB00-070a.pdf
Old Jul 7, 2004 | 06:31 AM
maxcozmo's Avatar
umm, ok. So is it a catalytic converter, or 02 sensors.
maxcozmo's Avatar
gameover03, is your 2000 cali or fed emissions?
Old Jul 7, 2004 | 06:55 AM
gameover03's Avatar
Im In Ny So I Fed Spec,....
Old Jul 7, 2004 | 07:49 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
state doesnt matter. count your o2 sensors under the hood. look in front of the motor, if you have 4 then you are cali spec.
Old Jul 7, 2004 | 08:08 AM
gameover03's Avatar
I Have One O2 Sensor
Old Jul 7, 2004 | 09:37 AM
maxcozmo's Avatar
You should have more than one sensor ..
Old Jul 7, 2004 | 09:39 AM
maxcozmo's Avatar
I have the same code also, but the light just stays on. I hate the dealership, so I will wait until the car dies first.
Old Jul 7, 2004 | 09:59 AM
sloppymax's Avatar
you may have one that is malfunctioning but youve got at least 2 o2 sensors. fed=2 o2 --cali=4 o2
Old Jul 7, 2004 | 11:27 AM
maxcozmo's Avatar
If P0430 is just like the P0420, just a different side of the car, what is one to do? Will the reflash or reprogram work also?
Old Jul 7, 2004 | 11:28 AM
maxcozmo's Avatar
So P0430 should have nothing to do with a new rear section?
Old Jul 7, 2004 | 02:53 PM
Max_Vader_2K's Avatar
I had this code, Dealer said I needed a new CAT. Got one from Warpspeed and the code went away been about a week now and still no light!
Old Jul 8, 2004 | 01:48 PM
maxcozmo's Avatar
This may sound odd, but do cali specs maximas have more than one cat? Or do they all have the same?
Old Jul 8, 2004 | 03:17 PM
Maximaum Driver's Avatar
My 2000SE has 2 Precats (Bank 1 and Bank 2) and 1 Catalytic. My Bank 1 blew (TSB but I was out of my warranty). It's a California spec.
Old Jul 9, 2004 | 07:55 AM
gameover03's Avatar
autozone told me this...
" the pcm has determined that the catalyst system efficiency for bank 2 is beow threshold for the current engine operation conditions. (bank 1 identifies the location of cylinder #1, while bank 2 identifies the cylinders on the opposite bank.)"
I have a fed spec...can n e on help me out...
Old Jul 11, 2004 | 08:21 PM
maxcozmo's Avatar
Will this code effect emissions testing?
paulpearl
Sep 2, 2015 07:50 AM
FriscoMaxima
Feb 10, 2005 01:26 PM
FLO_BOY
36
Aug 20, 2003 10:20 PM
pmas76
May 27, 2003 10:10 AM
