I messed up my car
Old Jul 11, 2004 | 04:43 AM
fred reid's Avatar
I messed up my car
Help:
I cleaned the trottle on my 2000 max VQ20DE engine using carb cleaner. When I put everything back together the engine would repeatedly race to 2k then drop to 1.5k over and over again. There is proper accelleration but I do not need to use the accellerator to drive within the city, the idle speed is so fast.
What could I have messed up?
Fred
Old Jul 11, 2004 | 05:47 AM
-Red-'s Avatar
Its your MAF sensor, if you're lucky, mabe you can carefully clean it off, but if not, it will need to be replaced.
Old Jul 11, 2004 | 05:55 AM
Cubanato's Avatar
Joo wanna play??......ok we go to war
no i highly doubt its the maf sensor.......maximapolak cleaned his TB as well and his idle went up to 900
somehow you messed up the butterfly in teh TB
-J
Old Jul 11, 2004 | 06:01 AM
-Red-'s Avatar
Not being able to go past 2k RPM is one of the symptoms of a blown MAF. Besides, I between a fragile MAF and butterfly, I'd say there is much more of a chance that his MAF sensor is the problem.
Old Jul 11, 2004 | 06:32 AM
MaximaPolak's Avatar
-J
My light finally turned off (after taking it off and cleaning it totally) and now all i have to do is reset my idlle....sorry the 2k3 is defferent from yours...
Old Jul 11, 2004 | 07:28 AM
Progress's Avatar
It's business time.
You're not supposed to use carb cleaners on our cars. The appropriate cleaner would be air intake and manifold cleaner that is not caustic to the intake. Carb cleaner is for cars with carbs and it may have eaten away at the lining of your TB or maybe messed up a sensor.
Do you have any codes?
Old Jul 11, 2004 | 07:29 AM
silvermax2k2's Avatar
also unplug the mafs wire clip from the MAFS itself, make sure they are making good contact, and that the wires going to the pulg are all intact and not cut/damaged. this has happened to me before.
I highly doubt it would be the butterfly, puting much more trust that it is the mafs. good luck.
-Chris
Old Jul 11, 2004 | 07:38 AM
irish44j's Avatar
retired moderator
does your maxima have a carb? then why would you use carb cleaner. Like ABDomega said, carb cleaner can eat away at certain components of FI (fuel injected) engines...seals, sensors, etc....
I'm holding a bottle of Gumout Carb/Choke cleaner (that I use on my lawn mower) and the back of the can specifically says "not recommended for fuel injected vehicles"
I use CRC or Gumout Air-Intake and throttle body cleaner.
lesson to all: always read the can carefully before spraying any **** on/in your car!
reminds me of my Honda, which took a special power-steering fluid (made for all hondas) because regular power steering fluid that ALL other cars use will eat away at the valves in the PS system. I learned the hard way about this after having to replace my steering rack.....now I always read the can and shop manual for fluids/cleaners...
Old Jul 11, 2004 | 07:53 AM
Cubanato's Avatar
Originally Posted by fred reid
Help:
Fred
by the way ...you have a VQ30DE not a VQ20DE
-J
Old Jul 11, 2004 | 08:07 AM
NYPD-Arnold's Avatar
Z
-J
He lives in Trinidad and Tobago, they have a 2 liter engine in their Max and it's called a VQ20DE.
Old Jul 11, 2004 | 08:12 AM
Cubanato's Avatar
why is that ??
-J
Old Jul 11, 2004 | 08:35 AM
Z
Emissions. More than half of this world has restrictions on engines over 2.2 liters. Israel just started to introduce cars with 3 liter engines and some countries don't allow anything more than 1.7 liters for example.
Old Jul 11, 2004 | 08:49 AM
fred reid's Avatar
I messed up my car
Thanks for all the responses. I was able to eventually find the problem. I bought the car doing 37K kilometers. Apparently the last person to attend to it simply turned up the trottle stop screw instead of cleaning the trottle.
After I got rid of all the gunk in the trottle I needed to turn the stop screw back.
Thanks again, this is a great forum.
Old Jul 11, 2004 | 10:36 AM
panda_1's Avatar
i agree with abd, you made a big booboo. check if you tb is still smooth on the inside. push the butterfly plate and run your finger on the inside of the tb. for future notice your supposed to use intake manifold cleaner. Good luck
Old Jul 11, 2004 | 11:17 AM
irish44j's Avatar
retired moderator
a big reason why alot of foreign cars are so big on turbo....just look at Audi and VW using the 1.8T because it gives power but still is good for emissions because it's ONLY 1.8 l......go to Italy and everything's a turbo it seems, and all the engines are 1.5-1.8 liters...Fiat, Alfa Romeo, Citroen, Seat, etc....
Old Jul 11, 2004 | 11:25 AM
Z
Yeah, I've always wanted an Audi A4 1.8T. Such a kick *** little car.
Old Jul 11, 2004 | 11:59 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
Audi 1.8L turbos suck... K03 Turbo by KKK will go out on ya at around 50K miles no matter how well U maintain the car. The engine is pretty much maxed out with built bottom end and all the tricks at 350WHP. My G20 has stock internals good for 450WHP. Nissan don't build motors like they used to. Back in the day they had kick *** motors like CA18DETs, FJ20, RB20DET, SR20DET, or even a 320HP SR20VET. Now all we got is VQ this VQ that... not that its a bad motor but I'm getting sick of seeing mini vans with what used to be a Maxima exclussive motor.
EDIT- I used to own a 00 S4 with all the bolt ons before my Maxima, and I'm a certified Audi Technician with years of experience on german crap.
Old Jul 11, 2004 | 12:09 PM
Z
Yeah, I heard Audi's have a **** load of problems and their maintence costs = too much $$$$$
Old Jan 1, 2008 | 03:27 AM
zhang210's Avatar
Engine Shake after changing MAF
my maxina 2001, MAF fail so just changed a new one.
But the engine always try the lower idle speed, it get 750 rpm first, and then try to 600 and even 550. So, the car is shaked and then return a bit high.
I have no equipement to measure it. I've runned about 100 KM, but it is still same.
Can someone help to tell how to let ECM remember the proper idle speed?
Old Jan 1, 2008 | 09:27 AM
joshz's Avatar
Hova
trust me, you don't.
it's more work than play
Old Jan 1, 2008 | 09:45 AM
Stardust's Avatar
F---ing Kangaroos
My God people are soooooo stupid, they dig up 3.5 year old threads to post useless crap that should have been posted here to begin with. http://forums.maxima.org/showthread.php?t=365289
Old Jan 1, 2008 | 10:33 AM
maxspeed96CT's Avatar
The original VQ...
Ya I was looking at getting new S4, but heard audi had alot of problems.
tho guys on the forum seem to say they are fine, i stayed ith the VQ
Old Jan 1, 2008 | 10:38 AM
joshz's Avatar
Hova
my parents have 2 audis... they always are calling me to find someone who can fix them lol.. ones a 01 the other is an 05 i think... theyre nice cars... if you have the time and money to keep up with them
Old Apr 24, 2009 | 05:02 PM
2damax's Avatar
uhhhhh disconnect the negative cable for a generous amount of time and then warm up the car for a little....like you should most the time you work on a car
Old Apr 25, 2009 | 07:42 AM
HotshotVQ35's Avatar
ibtl
Old Apr 25, 2009 | 02:36 PM
Derrick2k2SE's Avatar
I have to agree. I sold VW for 2 years and those 1.8 liter cars suck. I've dealt with a lot of used Audis as well and have never been impressed with one. Good luck on even making it to the timing belt change before the plastic water pump fails.
They're over enginered with overly complex and fragile electronics. All without much benefit.
Old Apr 25, 2009 | 06:44 PM
maxdriver10's Avatar
Audis are not kickass aside from an RS4 and that's only cause it has a V8. My 2000 VQ30DE-K Max w/4-speed auto and 2-12" subs in the trunk ran a .83 seconds faster in the quarter-mile than my buddys 2003 1.8T Passat (VW but same power as Audi) w/5-speed manual
MikesChevelle
Nov 23, 2024 11:17 AM
alixc
Aug 11, 2020 01:48 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
