Bad MAF sensor?
Old Jul 11, 2004 | 05:43 AM
durckelg's Avatar
Bad MAF sensor?
How do you know if a MAF Sensor is bad? I have noticed that my low end power is very inconsistant under 3500 rpms. I have no check engine lights. I drive an auto 2003 SE with 22000 miles.
Old Jul 11, 2004 | 12:26 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Very little power at low RPMs, engine feels really sluggish when the MAF craps out. Another tale tale sign is when the car stops accelerating past 2400RPM- it goes into LIMP mode. 60MPH is max speed then and computer ignores throttle input over 25%- cutting off fuel and ignition. Car will die out if U floor it under LIMP mode. Since ya have a 03 I would suggest taking it into the dealer- any of the local ones around here for the Technicall Buletins that are out for the sucky drive by wire technology.
Old Jul 11, 2004 | 08:54 PM
6spmax's Avatar
What TSBs are out for the drive by wire system? Does that system screw up the MAF? Just asking because I've never heard of any problems with DBW.
Old Jul 12, 2004 | 11:06 AM
durckelg's Avatar
Will a blown MAF sensor behave the same way as an unplugged MAF sensor? I have unplugged the MAF sensor and I definitely noticed the car performed much worse. Is there an in between hit to performance that can be caused by a MAF sensor not working optimally?
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
