View Poll Results: Front brake setup for a 2002 Max
OEM rotors and Hawk pads?
0%
OEM pads and Powerslot rotors?
20.00%
Hawk pads and Powerslot rotors?
80.00%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
2002 front brakes
Old Jul 20, 2004 | 06:22 PM
GimmeTorq's Avatar
2002 front brakes
Well, I'm fed up with rotor warpage... Dealer just keeps resurfacing the OEM rotors (twice already in 22k miles) . I'm looking for a brake pads and rotors combination that gets rid of this annoying rotor warpage and steering wheel vibration.
I'm satified with the braking power and quietness of the OEM setup, so I'm basically looking for comparable braking power and quietness and no warpage.
I'm looking for recommendations based on your experience. Some people has had good luck running different pads with OEM rotors. I'm currently considering OEM pads with Powerslot rotors to replace the current OEM pads/OEM rotors setup hoping that better quality rotors would do the trick...
Let me know what you think...
Old Jul 21, 2004 | 08:28 PM
GimmeTorq's Avatar
anyone????
Old Jul 21, 2004 | 08:40 PM
irish44j's Avatar
retired moderator
none...powerslots will not reduce warpage. Hawk pads will not reduce warpage. The problem is simply the rotors are too small for the car. The solution?
get what I have, it works like a charm and I also just put them on my buddy's 2k1, who has no other mods and is not into modding - and he loves them.
btw, the 2k-2k3 rotors are 10.4" rotors. These use the 12" rotors from the 2k4 maxima.....
http://www.mattblehm.com/relocation_kit.html
Old Jul 23, 2004 | 10:21 AM
Edward Lee's Avatar
Why go with the larger heavier rotor and increase your unsprung weight. Just get yourself some frozen rotors and problem solved. Frozen Rotor site
Old Jul 23, 2004 | 10:57 AM
chinaonnitrous1's Avatar
frozen rotors arent the answer....2k4 rotors have way more advantages besides non-warping. Since the brake caliper is spaced outwards further, there is more stopping power, way less heat, just overall a better performing setup.
Old Jul 23, 2004 | 11:05 AM
Edward Lee's Avatar
Frozen rotors were the answer for me. No more warpage!
Old Jul 23, 2004 | 11:40 AM
nyautostyle's Avatar
but doesnt it not fit the 17" stock wheels? I would think if i hit a pothole... i'm screwed
Old Jul 23, 2004 | 02:04 PM
schernov's Avatar
How many miles do you have on them? What pads are you running?
Old Jul 23, 2004 | 03:17 PM
imported_JIC_A33
http://www.stillen.com/Sportscars_de...d=36896&page=1
these look nice and not too expensive. I wonder if they fit under OEM 17s
Old Jul 23, 2004 | 03:31 PM
mclarengts1's Avatar
how hard is the install on the 2k4 rotors
Old Jul 23, 2004 | 04:09 PM
irish44j's Avatar
retired moderator
nyautostyle - yes, the 2k4 rotors with the OEM calipers fit under the 17" SE rims. What does hitting a pothole have to do with anything...if you mean if you bend your rim...not a problem...unless you totally "taco" the rim....there's still enough clearance if you happen to bend the rim (believe me, I bent one last spring in a huge pothole)
mclarengts1 - it's pretty easy....takes about an hour with basic tools the first time you do it.
+1 on what chinanitrous said....
Old Jul 23, 2004 | 04:59 PM
Edward Lee's Avatar
Frozen Rotors
The Frozen Rotors were purchased and installed on October 31, 2003 along with some Performance Friction Z-Rated pads. They probably have about 12k on them and there are no signs of warpage. In addition, they are the quickest stopping brakes that I have ever run on the Max or any other car for that matter, except for the Brembo/Baer Combo on my 5.0.
Old Jul 23, 2004 | 05:25 PM
imported_JIC_A33
the blehmco kit does NOT fit 02-03 maximas... i wish they did......now i have to drop 900 for a $tillen kit
EDIT..matt knows about it(great guy BTW)
see how the pad is NOT touching the rotor by almost 1/2"
Old Jul 23, 2004 | 05:35 PM
irish44j's Avatar
retired moderator
?? you sure about that....to my knowledge all the 5th gen maximas have the same brakes, except the 02-03 rotors are a TINY bit thicker....did Matt say it didn't fit the 02-03?
Old Jul 23, 2004 | 05:36 PM
irish44j's Avatar
retired moderator
nevermind.....that's odd....my pad has just maybe 5mm of overhang....
imported_JIC_A33
irish..see above..
Old Jul 23, 2004 | 05:38 PM
imported_JIC_A33
it was a learning experience for both of us. oh well. 2 me ANY overhang is No Good
Old Jul 23, 2004 | 06:10 PM
irish44j's Avatar
retired moderator
yeah it bothers me a little, but it's more than made up for by the fact that my rotors are not warped...
Old Jul 23, 2004 | 07:50 PM
Edward Lee's Avatar
No overhang w/Frozen Rotors.
Old Jul 23, 2004 | 08:00 PM
irish44j's Avatar
retired moderator
As you can see, I am a rep for BlehmCo and Edward Lee is the president of frozen rotors j/j
I would hope not!
Old Jul 25, 2004 | 10:00 AM
GimmeTorq's Avatar
Hmm... did not know about frozen rotors...I need to look into that. Thanks for the info!!!
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
fastcarny
Aug 12, 2015 03:50 PM
yat70458
Aug 3, 2015 01:16 PM
