Brembo Blank Rotor Write up?
Old Jul 22, 2004 | 08:02 AM
husker_max's Avatar
Just received my new bembo blanks and hawk pads today. Need to install them soon and wondered if there was a write up on here about it. Was going to look through all the old posts, but I see they are now gone.
Anyone?
Thanks!
DC
Old Jul 22, 2004 | 12:24 PM
husker_max's Avatar
OK....well can anyone at least tell me how difficult it is to put on these new rotors and pads?
Old Jul 22, 2004 | 12:36 PM
PoLo's Avatar
2-Wheelin it...
14mm removes caliper (2, 1 on top, 1 on bottom)
17mm (unsure, but i think so) removes caliper bracket (2)
the rotor may be rusted on, but after the caliper bracket comes off, the rotor should LITERALLY come right out. i took a rubber hammer and smacked it a bit and it came loose.
slap new rotor on, bracket goes back on.
make sure you grease the spacing between the shims and the pads. also make sure where the pad sits, that it's clean aka any rust spots or bumps. that's where the pad rides so you want it's path clear. place pad, use piece of wood and c-clamp to push caliper piston back (thicker pad means the piston is already in cause it's what held the old pad in) before you do that though, unscrew the brake fluid cap. keep an eye on it so that when you push the piston in, the fluid level will rise. if it looks like it's gonna spill, soak some up with paper towel. put caliper on again, tighten up. pump pedal couple time until you feel the piston hits the pad. repeat on other side. when all is said and done, check fluid level. if you soaked too much, fill to level. if not, then just close up fluid cap. last but not least, and please don't forget........put your wheels back on
as much as this looks like cliffnotes, there really is nothing more to do. enjoy
Old Jul 22, 2004 | 12:55 PM
GeneYes_Se5spd's Avatar
When i had my volvo, I read that the disks that IPD sells had to be cleaned off with somekind of grease remover, is it not the same case for brembo blanks or other disks in general?
Old Jul 22, 2004 | 01:27 PM
NYC TAR's Avatar
every new rotor has grease in it ( for preventing rusting during storage) just use some crc brake cleaner to clean it off.
Old Jul 22, 2004 | 01:43 PM
husker_max's Avatar
Thank you everyone...that is what I needed.
Old Jul 22, 2004 | 02:08 PM
scopium
polo if u dont mind i posted your write up on the How to section for future
DJLAX152
May 4, 2021 11:46 AM
Apr 16, 2020 05:15 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
