need a new coil
Old Jul 26, 2004 | 10:36 AM
davemax's Avatar
need a new coil
I need a new coil on a 2000 maxima SE. Is there a way to test them and see which on has gone bad? And which piston bank it is front or back??
Please Help
Old Jul 26, 2004 | 01:39 PM
ZIPPIN's Avatar
Mauja He Mauja
how many miles does she have? i would receommend replacing all 6 at the same time. sooner or later they will all go bad..
Old Jul 26, 2004 | 02:19 PM
Gennady7's Avatar
There are people on this forum selling new coils.
Check out:
http://forums.maxima.org/showthread.php?t=280643
Old Jul 26, 2004 | 02:30 PM
davemax's Avatar
The reason I need to narrow it down to one. Is that the car only has 40k miles on it..
Is there some wite up on testing these things?
Old Jul 26, 2004 | 02:49 PM
takkar's Avatar
I wanna know too!!
Old Jul 26, 2004 | 02:53 PM
filtor1's Avatar
As far as I know, there is no DIY technique to test coils. A diagnostic machine is necessary. I also recommend changing all six. If you haven't done your spark plugs, I would do them as well(money permiting).
Chris
Old Jul 26, 2004 | 06:09 PM
Omegasrk's Avatar
Chris
Actually, there is a way to determine which coil(s) are failing. On my car for example, I am getting the check engine light on pulled these following codes:
P1320: Bad ignition signal sensed
P0300: Mulitiple cylinder misfire
P0301: Cylinder #1 misfire
Knowing this, I pulled out my DMM (digital multimeter) and started to test each of the ignition coils on the car for resistance. On each coil there are 3 prong. They are labeled as:
1: (E)nergy
2: (G)round
3: (Ig)nition
So If you place your DMM probe on Ground and Ignition you should be able to read a resistance. Note: If you accidently probe Ground and Energy, it will show 0 ohms. A good coil will show a resistance and a bad coil will show none according the Nissan Service Manual for the 2000/1 Maxima (VQ30DE).
For my car:
Coil 1: 0 ohms
Coil 2: 1.96 K-ohms
Coil 3: 1.82 K-ohms
Coil 4: 1.84 K-ohms
Coil 5: 1.92 K-ohms
Coil 6: 1.83 K-ohms
Note:
...........................Firewall Side
............................1 3 5
............Coils/Cylinder
............................2 4 6
........................Radiator/Front of Car
Thus from my guess, since coil #1 is faulty (P0301) it sent the bad signal to the ECM for timing (P1320) and cause the other coils to misfire (P0300).
BTW, I am in contact with Nissan North America right now regarding about these faulty coils we have in 2000/1 Maximas (TSB NTB01059 ). They do cost a lot of $$$ and Nissan should do a recall on them. I have over 140,000+ miles on my cars, so it is obvious I am out of my warantee. My Nissan North America advisor is Coleman (310-771-8473) and I have disclosed all my personal feeling about this situation to him and what other 2000/1 Maxima owner think also from the Online Petition for a Recall (http://www.petitiononline.com/NIS_IGN/petition.html)
Please...if other Maxima owner feel Nissan should a recall, call Coleman or Nissan North America (1-800-NISSAN-1) how you feel and e-sign that petition if you haven't so. I told Coleman I am #416 on that petition. My next move is to contact the BBB and the NHTSA about Nissan's reluctance for a recall.
steve...
Old Jul 26, 2004 | 07:07 PM
filtor1's Avatar
I stand corrected. You should submit this info to studman to be included in the 5th gen how-to sticky if you haven't already. Thanks for the information. This definitely needs to be in a sticky.
Chris
Old Jul 27, 2004 | 05:20 AM
davemax's Avatar
Thanks Omegasrk
But when you check the resistance with your DMM is the car completely off or is the key turned until the lights on the dash is on.
Old Jul 27, 2004 | 11:17 AM
Yaco_Max's Avatar
Check this out
Please Help
Please......do it!!!
Old Jul 27, 2004 | 11:19 AM
Yaco_Max's Avatar
NO matter how many miles you had in your car something if wrong with them.....
Old Jul 27, 2004 | 11:17 PM
Omegasrk's Avatar
Thanks Omegasrk
To test them properly, you need to remove the ignition coils from you car. That way you could see all three prongs and attach the DMM probes to (G) and (Ig). The label for the prongs are on the body of the coil near them. You'll be able to see the:
(E)nergy
(G)round
(Ig)nition
BTW...Take out your coils from you car when the engine is cold. Handling hot coils is not fun at all.
steve...
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
