Rattling sound...
Old Jul 29, 2004 | 09:02 AM
Pri63's Avatar
Rattling sound...
What up...my sister has a 2000 I30t same engine as our...she has recently noticed a rattling sound when she accelerates from standing...but after that it goes away....has anyone experienced this? She took it to the Infiniti Stealership and they found no problems( stupid ) and no codes. Any ideas what it could be, she's rolling onto 86k...could it be the timing chain?
Thanks....
Old Jul 29, 2004 | 09:05 AM
linuxr's Avatar
Im just guessing here, but might be a heat shield on the exhaust system.
Old Jul 29, 2004 | 12:00 PM
NewLoveI30's Avatar
Knocking? Dose she have the old coils?
Old Jul 29, 2004 | 12:02 PM
Pri63's Avatar
Most likely yes...but wouldn't faulty coils throw codes??
Old Jul 29, 2004 | 12:38 PM
GeneYes_Se5spd's Avatar
double the heat sheild! it will usually make noise when you're either idling or accelerating. Its a very metalic noise, almost like a muffled sound of two screw-drivers hitting together.
Check that out and give us a holler.
Gene
Old Jul 29, 2004 | 01:23 PM
kobalt's Avatar
I had a rattle at acceleration & idle when I bought my MAX - turned out that the heat shield needed adjustment.
Old Jul 29, 2004 | 01:44 PM
NewLoveI30's Avatar
Not Necessarily. I had mine replaced under warrantee and I wasnt throwing any codes.
About this heat shield... Which one seems to give the problems?
Old Jul 29, 2004 | 03:18 PM
Progress's Avatar
It's business time.
Why do heat shields rattle like that? Are they loose or something? How can they be tightened?
Old Jul 29, 2004 | 03:50 PM
yeah, they get loose, all you have to do it tighten them. I believe some cars have them sitting on rubber gromets, so i would replace those. Otherwise, just give it a good tighening. The reason the shake loose, i believe, has to do with the fact thats its a thin peice of metal with a large surface area the gets shaken from the vibrations of motor/road irregularities, and the contraction and expansion due to heat.
Gene
user 11122324
42
Jul 18, 2022 03:35 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
