!!! Help !!! P0507 - Isc System !!!
Old Jul 29, 2004 | 04:09 PM
Tac_M's Avatar
I cleaned my throttle body and now I’m getting SES light: P0507 - ISC SYSTEM
Also it idles litle to high @ 950-1000 rpm...
What did I do wrong???
And how do I fix it???
thanks !!!
Old Jul 29, 2004 | 04:28 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Why in hell would you need to clean your TB on a 2K3?!? Talk about ****.
My guess is if you used a cleaner spray, it all ran down through the little passage way infront of the throttle plate and gunked up the IACV valve.
I'd remove it and clean it.
Old Jul 29, 2004 | 04:59 PM
Tac_M's Avatar
it looks like the only hole there is an EVAP line and it's on the side... so i don't think i gunked anything up ....
Old Jul 29, 2004 | 05:05 PM
IceY2K1's Avatar
Okay...I forgot to look at the 2K2+ FSM.
2K2 FSM says:
P0507 Idle speed control system RPM higher than expected.
Possible cause:
1)Electric throttle control actuator
OR
2)Intake air leak<~~~~my guess
Old Jul 29, 2004 | 05:06 PM
IceY2K1's Avatar
You can try to peform the Idle Air Volume Learning procedure if you don't find a leak.
Check the How To's or TechnoSquares' website.
Old Jul 29, 2004 | 06:17 PM
Tac_M's Avatar
This solved it!!! Thank you!!!
Dude I was thinking I broke the servo in the TB … I was like "NO 600 bucks !!!! "
Old Jul 29, 2004 | 06:26 PM
IceY2K1's Avatar
I guess it really did need cleaning, if it changed the idle air flow enough to cause that. Hmmmmnnnn......
Glad to help~! Just remember that "$600 savings" when the .org donations are accepting/working again.
Old Jul 29, 2004 | 07:09 PM
schernov's Avatar
shouldn't you be still under warranty?
Old Jul 29, 2004 | 08:26 PM
Tac_M's Avatar
Yes it is. But, everything that has been done to this car was done by me - mods, maintains, audio, everything.
nobody touches my ride !!! thank you .org for making it happen!!
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
RWCreative
Sep 21, 2015 11:01 AM
