Clutch Problem ***6 speed ONLY***
Old Aug 1, 2004 | 09:28 PM
Igor911's Avatar
Hey Guys
I just noticed a couple nights ago that I need to push my clutch down much further in oder to put my car into any gear. I can't even shift smooth anymore.
Like before i needed to push my clutch 3/4 of the way to shift, now it needs to be on the floor pretty much. Car has 22k miles.
I read somewhere it can be adjusted. I also read u can adjust the height of the pedal, but I dont want to do that. I need to know if either my clutch is bad or if it can be adjusted elsewhere?
Please help
Old Aug 1, 2004 | 11:35 PM
HitManSE's Avatar
Make sure its not low on fluid, check the clutch slave as well. The clutch being bad should have nothing to do with how far down you need to push the pedal in order to put it in gear.
The only thing a bad clutch will do is slip.
Old Aug 2, 2004 | 01:04 AM
MiniRX7's Avatar
I have this same problem. Noticed that i am starting to grind 3rd.
I have 51,000kms on my 2k3.
Changed to Redline from 0-12,000kms
Changed to Amsoil S2000 @ 25,000
Changed again to Amsoil S2000 @ 40,000
Old Aug 2, 2004 | 05:53 AM
Triple8Sol's Avatar
I miss the .org!
Dealer is replacing my slave cylinder. It makes a loud clicking noise when I press and depress the pedal. Do you have any similar noises?
Old Aug 2, 2004 | 06:14 AM
Igor911's Avatar
What is a clutch slave? I checked the break fluid next to the steering column and its fine.
Old Aug 2, 2004 | 06:56 AM
Cutler's Avatar
Look in your manual, it should tell you the location of the slave cylinder
Old Aug 2, 2004 | 07:29 AM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
I think the 3rd gear synchro is screwed in my car. I've been trying to get the dealer to fix/replace my tranny for a couple months now. Whatever the problem is, get it fixed B4 the warranty is up.
Old Aug 2, 2004 | 10:25 AM
NoMotive's Avatar
oh so that clicking noise isnt supposed to be normal...
Old Aug 2, 2004 | 11:44 AM
PoLo's Avatar
2-Wheelin it...
what's the brake fluid have anything to do with this?
Old Aug 2, 2004 | 12:00 PM
Igor911's Avatar
I meant the jar next to brake fluid....
Typo
Old Aug 2, 2004 | 12:12 PM
studman's Avatar
I have the same clicking problem, but the car isn't under any warranty anymore (except powertrain). How hard is it to replace the slave cylinder?
Old Aug 2, 2004 | 01:01 PM
studman's Avatar
I just talked to Dave Burnette. He says that the Slave Cylinder will never ever make a clicking noise. He seems to think that the noise that I am hearing is either the Cruise Control Cancel Switch or the Clutch Pedal Position Switch.
Max139617
Oct 19, 2016 11:34 AM
BkGreen97
Apr 2, 2016 05:47 AM
I<3 A32's
Sep 10, 2015 11:07 AM
slowlifer
Sep 8, 2015 05:53 AM
Max139617
Sep 6, 2015 06:02 PM
