S - Afc 2
Originally Posted by look2me40
Mine is mounted above the steering wheel, partially blocking the rev meter and TOTALLY BLOCKING THE GAY A.S.S. SES light.
Im either thinking about mounting it next to my radio in a pocket that I will fabricate or in the sunglass holder....
Originally Posted by Igor911
you do know that you can take the cluster out and remove the SES bulb?
Too much work for something I can just hide from view. Besides, I like it right there in front of me. It isn't blocking enough of the RPM guage for me to care...besides, I can see RPMs in digital.
Originally Posted by IceY2K1
What's with the thermometer?
That's what I figured you were doing. I was going to try that with my multimeter, but that's a more permanent solution.
What's the temp like once you start driving? Have you tried measuring any intake temps?
iirc...this is kinda like a dead horse subject.... with all the above mods...i think 3-4 hp was the average or expected gain. Wasn't much to boast about except for the serious boosted people. But still would be a gain.
Originally Posted by Oxidizer2k
No one answered nismo maxes question.. What kind of gains can be expected by installing this? Thanks.
Here is my quote from this thread for what its worth. I don't know about HP, I am not a believer in HP or dynos. What it does for my 1/4 mile time is my gauge for whats happenin.
http://forums.maxima.org/showthread.php?t=329341
Ok here is my take on the S-AFC II.
I got mine to alter the a/f for nitrous. However I had it for a year before I got a wideband. No wideband, no way to tell your a/f so therefore it sat there idle. I am not a believer in Dyno widebands because they don't load the same as real life, therefore I do my adjustments at the track or occasionally on a quiet road.
Oh ya before I forget about the o2 sensor thing, I use the simulators because I don't have a cat otherwise I would just extend the wires.
I decided to use one setting on the s-afcII for N/A and one for nitrous. So I started with setting up the N/A and was very surprised at the amount of fuel I had to remove to get the to 13.2-13.4 which I use as a N/A base. Currently it ranges from -6% to -11% which I feel is quite a bit for a set of headers and an intake for mods. I wish I had of checked it stock.
However with nitrous its another story I actually have to add fuel to bring the readings to 11.8-12.0, not much, between 1 and 3%.
If I was just running N/A I would buy a s-afc knowing what I know now. It actually took 2/10ths off my 1/4 time. What would it do stock, I have no idea but it would be interesting to find out.
Does the ECU alter the settings after I adjust them? No, the a/f has remained constant since first setting a few month ago.
End of rambling.
PS Would I buy a TS ECU? Not until someone convinces me it will make my car quicker. I ran a 12.5 @ 108 last sunday on a 30 HP shot of nitrous with the stock ecu and run consistent 13.5's n/a. If someone does better than that on the mods I have then I will certainly consider it.
Y2KevSE
40
Jan 23, 2002 03:23 PM
gould2000
Nov 2, 2001 11:59 PM
blah!
