Can any1 tell me HOW to remove my front bumper on a 2K1??
Old Aug 6, 2004 | 05:26 AM
96/01 Max's Avatar
I checked the How-To threads and also the FAQ's I didn't see anything that specifically or indirectly dealt with the removal of the front bumper.
I'd like to remove my factory fogs and replace them with after market angel eye fogs.
I didn't know where to begin, any help would be greatly appreciated.
Thanks for your patience.
Old Aug 6, 2004 | 06:59 AM
PoLo's Avatar
2-Wheelin it...
not hard at all...if it's anything like my 2k2 removal.
remove all clips under bumper, this is what holds the splash shields to the bumper.
there are also 2 screws at the ends of each side, above the sidemarker. 1 at the VERY edge and antoher 6" away. remove those 4.
next there should be like 4 or 6 clips holding the top of the grill area to the cars frame. remove those. should come off easily. took me half hour to swap bumpers.
Old Aug 6, 2004 | 07:25 AM
96/01 Max's Avatar
I'll try that..thanks for the tip.
Is there any special way to remove the clips? I always find a way to break those things.
Old Aug 6, 2004 | 07:59 AM
PoLo's Avatar
2-Wheelin it...
the ones at the ends are just screws. unscrew them.
the clips on top i believe you just pop out. or they may be like the bottom ones, which you just unscrew about 1/2 turn until you see the clip pop out a bit, after that just pull on it or get a screw driver and lift it up. believe me, it's rather easy.
vingodine
45
May 21, 2016 12:46 PM
Max139617
Aug 29, 2015 02:55 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
jomax14
Aug 12, 2015 11:49 AM
