Ignition coil problems
After doing a search on google, I've been able to determine that this is a somewhat systemic problem so I appologize if this topic has come up brfore.
I only have 43,000 on my 2000 Maxima and my "service engine soon" light has just come on. This happened before at 22,000 miles and the dealer ended up replacing all 6 colis under warrantee. I became a bit scared when I was told that "these won't be covered under warrantee the next time"; obviously implying that they expected to see me back at some point.
Well the light has come on again and I took it down to Auto-zone for a free diagnostic and sure enough the code was "misfire or ignition problem". I had 2 instances of it so it did not identify which piston was effected.
Any ideas on how to fix this long term? Do the 2001 coils work in the 2000? They have a different part number and cost about 10% more so there must be some difference???? It does not appear that the 2001 has the same problem that the 2000 does.
Any ideas would be appreciated.
Jeff
Jeff
Man!!!
True or False I had been reading a lot about def coils 99 and 2y , and for some reazon the 2y1 looks a better option someone named steve toll me to upgrade to 2y1 so go a head and replace yours (all 6 ) and good luck...
Ok for starters, if the car is still under Warranty, they cannot deny you the free repair JUST because they fixed it before.
If there is a problem, that is a usual warranty issue, they have no choice but to honor it. Now, they could also have done the car long before the TSB was released and the new coils made. The coils now are different than the original from what I remember.
I do not know about the 01 Coils. Do you need diff plugs with those?
shilov
Feb 19, 2024 09:40 PM
mikeg75
Nov 30, 2015 05:12 PM
