Is there an easy way to get the grille off ?
I think the grill is in two pieces. The trim and the actual grill section. Look for 3 push type clips up top that hold it to the upper radiator support, then I think the rest just snaps out.
Originally Posted by maxima42
The grill is one piece, there are 3 screws holding it in from the back, two are on the lower corners, and the third is right in the center behind the nissan logo
I don't think there's an easy way to get at the backside...
How do you get the Nissan logo off without breaking it?
Thanks!
Originally Posted by 02SEinStL
Is there access to these screws from the front?
Thanks!
Thanks!
Originally Posted by DonGfun
Cut it ... I did looks great
Originally Posted by Bluesbrekr
You have to get the screws from behind the grille. It helps to have small hands. The grille pulls out after the screws are removed. After it's out, you will see 3 small tabs to release the logo.
since we are on the topic of grills.... i was thinking about repainting ym grill black or grey to match the body... anyone have tips, pointers or alternate suggestions? i know everyone here can get creative, im just looking to gather ideas
Originally Posted by Sp00ks01SE5spd
Have you tried clear coating it? Should reduce chipping.
Geez WTF were they thinking when they mounted it from the back...damn near every vehicle you can get to the screws from the front, I mean how hard would it have been?!? After all they're tiny screws and they'd be hidden back in a dark corner anyway! I just tried to get at the mounts and while I did squeeze my hand back there I can't even feel where the screws are, much less be able to get in there with a screwdriver.
End of rant, but I would still really like to give the idiot designer responsible for it a
[QUOTE=Bluesbrekr]I got the Super Black paint matched at a local paint store that specializes in auto paint. Logo is Testor's 'Boyd' Smoke Gray Pearl. Not that hard to do, but the grille chips easily. I have touched it up many times.
when you repainted it, did you sand off the original paint or just paint over? did you use a primer?
[QUOTE=sleotta]
The stock grille isn't painted, it's colored plastic. Washed with Dawn and rubbed with 000 steel wool. Then 2 coats of primer, then the black.
REDinLV
Aug 15, 2024 12:30 AM
adamgalazka
Feb 5, 2023 08:24 AM
Apr 16, 2020 05:15 AM
