Anybody with a placeracing intake help....
Old Aug 22, 2004 | 07:34 PM
klee215's Avatar
I read a thread and the person changed his cai setup to a wai setup with the placeracing intake and got some good gains.. But there is a O2 sensor on the lower piping and without the lower pipe what do u do with the loose sensor??
Also he attached the filter directly to the MAF, could that damage anything ??Please help... If anybody has pics of this wai setup please post ... thanks
Old Aug 22, 2004 | 09:26 PM
MyownNismo's Avatar
Future Camaro SS owner
what you do is use the stock intake part that the sensor was in.
Old Aug 22, 2004 | 09:35 PM
cobymoby's Avatar
You are basically looking at our setup. Except that our piping is polished aluminum instead of mild steel. We use the same filters as PR as well.
Old Aug 22, 2004 | 10:26 PM
MyownNismo's Avatar
yeah like that but he want's to know about the temp. sensor. See where the red part is you put the sensor back on to that. air will go through it and adjust accordingly.
Old Aug 22, 2004 | 10:33 PM
TEEdotMAX's Avatar
what do u do if u have taken all that stock intake stuff out?? is there another way to mount that temp sensor?
Old Aug 22, 2004 | 10:42 PM
MyownNismo's Avatar
It would measure the heat of engine bay so I would say it make the ECU think your getting hot air instead of cold air.
Old Aug 22, 2004 | 11:35 PM
klee215's Avatar
so if i install the stock front air duct where the temp sensor originally belong too, and continue the wai setup you think i 'll get any check engine problems?
Old Aug 23, 2004 | 07:01 AM
Kruppa's Avatar
isn't anybody else wondering how you gain performance from swapping out the cool air intake setup...I can't imagine how a WAI setup for a Place Racing Intake could gain any performance whatsoever over the cool air setup...if anything make it slower
Old Aug 23, 2004 | 07:35 AM
MyownNismo's Avatar
You won't get a SES. When I had the PRCAI I did the same thing and nothing went wrong.
Old Aug 23, 2004 | 09:30 PM
klee215's Avatar
hey myownnismo........
i know u have to bolt down the maf to the piping. did u have any problems with the filter coming loose from the maf since u cant bolt it together??? And did u see any power gains too??
Old Aug 24, 2004 | 06:53 AM
MyownNismo's Avatar
All you have to do is to do it like the Berk pipe picture above. Works out fine.
Old Aug 24, 2004 | 07:10 AM
spirilis's Avatar
Hmm. I might try out my new (used) PR CAI in a WAI layout like that. It'd remove the crap from the engine bay and give me some time to examine the area before cutting the hole.
Old Aug 24, 2004 | 11:04 AM
theMax's Avatar
There was a debate on if the extra bends in the CAI lower was robbing power than just the intake on the upper part. Seems like the difference is zero.
The CAI with lower made better gains on the low end and on really hot days and the upper was sometimes better at WOT. Either way no big difference.
I have went back and forth and no real difference,
BTW when I was using CAI with out the lower I zipped tied the sensor in front of the filter.
Old Aug 24, 2004 | 11:52 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
When I bought my Max brand new, 1st mod I did to it was JWT POP charger- only had it for 4 days. I let the intake air temp just lay next to the battery for over a year. Make sure its connected and you won't get a Check engine light. On 02-03 Maximas the sensor is built into the MAF.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
