HELP car wont start
Old Aug 23, 2004 | 08:28 PM
scopium
HELP car wont start
this has happened a few times
suddenly my car doesnt start
before i just waited a bit then i tried and it started..but now nothing
i turn the ignition and all the appropriate lights turn on but the car wont start..
whats going on?
sean
Old Aug 23, 2004 | 10:40 PM
JdoubleOe703's Avatar
teddibear703
i've had this problem too... i think its a 2k-2k1 thing... larry and andy expierenced it... its not duplicable... very frustrating
Old Aug 23, 2004 | 11:40 PM
scopium
i'm gonna take it to dealer in morning..
is this covered under warranty to be replaced..
i'm 90 percent sure its the starter
Old Aug 23, 2004 | 11:46 PM
FusionAcid's Avatar
happened to me too.
i got stuck 2 times. waited like 5 mins after being frustrated in the parking lot thinking how i will tow this **** & then it would start.
I also changed the ignition relay, ignition coils.
could it be the crank sensor? or starter perhaps?
Note: only happened 2 times in 1 year. & it wasn't my fault, i started it correctly.
Tell us what the stealership has to say. goodluck.
Old Aug 24, 2004 | 08:29 AM
paralyse's Avatar
I Miss My Maxima
Turn key and engine does not turn over or try to start at all: Ignition switch, neutral safety switch, clutch pedal switch, starter, starter relay, battery cables...
take your pick. problem needs proper diagnosis before you throw parts at it.
If the engine cranks over good but won't fire, look elsewhere.
Old Aug 24, 2004 | 08:49 AM
Progress's Avatar
It's business time.
Or it could be your immobilizer. That was my problem and I had to get a new one.
Old Aug 24, 2004 | 09:29 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
Next time something like that happens to ya... open up the hood, look down on the starter... then go open your drivers side door, click the button for the trunk. Pull out the lug wrench and wack the starter with it a few times. Get back in the car and see if it starts. My uncle has been doing that on his 98 GXE for like 3 months every once in a while till his starter gave out. I swapped a Nissan one in there for him and it fired right up on the 1st try. Took me whoppn 15 min to swap it using just some basic hand tools I brought with me - in a Walmart parking lot. If its a Immobilizer problem the little security light will be blinking while your trying to start the car. Next thing is have someone get in the drivers seat- turn off the radio, and pull out the rear lower seat cushion. Then stick your ear up to the fuel pump access cover and tell the person behind the wheel to turn on the ignition- but don't fire up the engine- if U hear the pump energize then... the pump is OK. Then have them crank while listeing closely if the pump is working. If the engine is cranking then its not the starter or the immobilizer btw. If its not cranking, 95% of the time its the starter. Just wack it with a tire wrench. Always worked for me at Nissan
Old Aug 24, 2004 | 08:55 PM
scopium
ok guys.. before i towed the car to dealer.. i did bang on the starter a few time..
then i checked the ignition fuse to see if it was burnt but it was ok.. and the pump seemed it worked..
very weird
after i got the car to dealer..
i try it for one last time and the car turns on.. WTF..
but i still leave it there and they couldnt find a problem..
i dont know what the hell is going on
Old Aug 24, 2004 | 10:03 PM
teddibear703
see... i knew it... dah, stupid nissans... i think its a common prob... i get the same prob every now and then
Old Aug 25, 2004 | 06:53 AM
crzyballa33's Avatar
You should definately check the battery, have you changed your battery since you got the car? I had the same problem, and after I replaced the battery, it started right up.
Good luck.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
