CAI Intakes
Old Aug 25, 2004 | 09:29 AM
sohailb's Avatar
CAI Intakes
If search were working, this would not have been asked.
Is there any real performance difference in the Place Racing and Injen CAI's?
I have bene looking for some info but thats proving to be too hard to find. I saw some pics, and it seems the Injen has multiple bends and looks more fluid, and the PR has just 1 bend and looks stiff. Could an extra bend make a performace hit?
-sohailb
Old Aug 25, 2004 | 10:06 AM
spirilis's Avatar
Probably not a difference based on the bends. But there should be a difference based on temperature--an Injen might not perform optimally in warm weather, especially with stop'n'go driving. A Place Racing CAI should stay cool.
Place Racing is more difficult to install due to the fact that you have to cut a hole in the fender and relocate the fusebox a little, plus remove the battery. So there are ups and downs of the 2. I recently bought a used PR CAI, but right now I have it installed as a short pipe (in fact, I'm not even using the midpipe; just the MAF adapter alone... the midpipe is too loud, especially with my recent exhaust leak making more noise). I'm planning to do the full install by this weekend hopefully.
Old Aug 25, 2004 | 10:19 AM
ZIPPIN's Avatar
Mauja He Mauja
i want the INGEN , but all the rain water scares me. i wish we could get hood scoops. they are just soooo ricey though. i have been thinking on scoops that can be closed when it rains and in the winter. it is just sooooo damn hot in the engine bay...
Old Aug 25, 2004 | 12:13 PM
sohailb's Avatar
I just talked to Steve at SWA and he told me that the PR CAI needs a whole cut in the fender while the Injen does not. he said the injen sits near the radiator under the battery. So I am guessing that the cooler air of the PR should yield more performance... and I am thinking minimal if any at best.
Old Aug 25, 2004 | 12:22 PM
spirilis's Avatar
Yep. About that cutout--if you buy a used PR CAI and don't have the cutout, see my thread here: http://forums.maxima.org/showthread.php?t=331882
You can email Place Racing for a copy of the template, and that thread has a link to the DesignCAD viewer program for viewing the file they send you (must use Windows to view it, and you should print it out with "Fit to Page" disabled so it prints out at the correct dimensions without zooming)
Old Aug 25, 2004 | 01:34 PM
Cevin's Avatar
How about if someone doesn't want to go to the extreme of modding the fender, is the Injen the next best bet? I've heard that Berk is the way to go.
Old Aug 25, 2004 | 02:23 PM
sohailb's Avatar
Ya I am still having a tough time deciding if I want to cut the hole for the PR or not.... so far I am leaning to cutting the hole and using the PR for the benefit of cooler air.....
Old Aug 25, 2004 | 05:19 PM
spirilis's Avatar
Yeah, you might as well get the Injen if you don't wanna cut the fender. At least you'll receive cold air some of the time.
Old Aug 25, 2004 | 05:40 PM
2k2kev's Avatar
It's chrome alright...
For the love of god an injen will NOT take in water unless you're driving through 18" of water, and if you do that you've got bigger problems.
.........and if you live in a flood zone, get a $40 bypass valve to 100% guarantee it won't happen.
Old Aug 25, 2004 | 06:18 PM
ZIPPIN's Avatar
Mauja He Mauja
^^^ i am very careful when i drive. no, i do not drive thru puddles of WA WA. i want a hood scoop really bad
Old Aug 25, 2004 | 09:34 PM
zachary1988's Avatar
I have a 2k2 with an Injen. Performance wise, I can feel some power in the mid range as most stated. I bought the Injen because it was a better deal with the group buy. You won't have to worry about water unless you drive through 18" of it as stated before because the filter is shielded by a plastic piece. I really like the way the Berks looks and it is cheaper. I have read may posts about CAI and since I think this is one of the cheapest and easiest mod, I did it.
Old Aug 25, 2004 | 09:54 PM
scopium
for the 34938743 times that this has been discussed.. injen cai is NOT a CAI..
having a filter hide behind the radiator is not considered cai.. same temperature as engine..
PR is true CAI..
plus the temp from engine and outside weather is only a difference of 2-5 degrees
BERK technology has the proofs
Old Aug 25, 2004 | 10:02 PM
sohailb's Avatar
So the Berk similar to the Injen? I think i am defintiely leaning heavy for the PR... ill take that 2 to 5 degrees...
Old Aug 25, 2004 | 10:07 PM
rule da road's Avatar
Dont forget about a weapon r. Less cost and for an intake it, really diameter is all that counts compared to crappy stock. Some people have built their own intakes from home. Its just air to the engine.
Old Aug 25, 2004 | 10:10 PM
2k2kev's Avatar
having a filter hide behind the radiator is not considered cai.. same temperature as engine...
....and for the 34938744 time the filter is NOT behind the radiator, it's below and beside it.
Old Aug 26, 2004 | 04:57 AM
Torgus's Avatar
+1
it's a damn intake it is only NOISE!!!!
show me where replacing an intake made more then .1 of a second in the 1/4.
Old Aug 26, 2004 | 06:25 AM
cobymoby's Avatar
Originally Posted by Torgus
+1
I've a few of my customers have shaved .2 secs of their times. I don't remember their names but if you search for a while you will find their posts.
aw11power
Oct 10, 2021 04:57 AM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Sep 27, 2015 08:37 AM
