The Home Depot Mod King Strikes Again...
Old Aug 31, 2004 | 01:39 PM
irish44j's Avatar
retired moderator
I took a sick day, but was getting a little bored so decided to take care of something - since I've had my intake in and the stock air box out there is a huge empty space in the engine bay that for some reason annoys me. So I decided to make a little "platform" so to say, to accomplish 3 things:
1. Get rid of that big empty space
2. Create a new mounting point for that plug/sensor (??) that hangs off the stock air box (and was just hanging there with the air box/scoop out of there)
3. Place to put stickers that is not on the outside of the car (Until falken, maxspeed, tokico, etc. start sponsoring me (yeah right) I'm not gonna advertise for them - but no harm in some under-hood decoration, right?
so, using a piece of cardboard I made a template of how I wanted it to look, then traced the form over plexiglass that was sitting in my basement. As you can see, there are some things sticking up and "in the way" that require cutouts for (including the coolant hose coming out of th radiator). Did the cutout using a jig saw (didn't work too well since I had the wrong blade), and also used a dremel with a bunch of cutitng/sanding attachments (also didn't work that well)...but eventually got it all cut out, sanded, painted, clearcoated, etc...it's mounted to the front lip of the engine compartment using cut-down anchor screws (normally used for screwing into hollow walls/drywall)....
so here it is -
Old Aug 31, 2004 | 01:41 PM
Progress's Avatar
It's business time.
That's a whole lot of work that I would probably never do. On the other hand, why did you take off the stock air scoop?
Old Aug 31, 2004 | 02:10 PM
irish44j's Avatar
retired moderator
without the stock air box there, all the scoop is doing is dumping dirt, bugs, road grime, etc. into my engine bay (believe me, you can see where it comes out)...besides, since it's only held in place by those two little plastic screws, it rattled around alot once the stock air box was gone. And again, I did it for looks to....I don't like the scoop there if it's not doing anythign useful.
as to the whole lot of work - like I said, I took a sick day from work and was bored - I did all this with stuff I had sitting around the basement/workshop so it was free...just something to pass the day, and building things is always fun (even though half the time the things I build turn out kind of wierd )
Old Aug 31, 2004 | 03:16 PM
Lytheum's Avatar
isn't there a sensor or something plugged into that air scoop? i put my intake on the other day and was going to pull that piece out too, but it looked like something was plugged into it, so i left it.
Old Aug 31, 2004 | 03:34 PM
looslip's Avatar
Horra!!
It looks like a radiator shroud. TET makes a CF one for the 4th gens. I brain is too tired to remember what they're good for tho, other than looking cool.
Old Aug 31, 2004 | 03:48 PM
irish44j's Avatar
retired moderator
yes, it's the air temperature sensor. But with an aftermarket intake, the ATS plugs into the midpipe now......the thing that's screwed tothe top of the scoop has nothing to do with the scoop itself, its some other sensor that's just mounted there for convenience I guess. As you can see, I have it mounted in pretty much the same place on my cover thingy....
Yeah, I believe the radiator shroud is there to redirect the fans' air or something. Ihave a shroud on my Triumph's radiator....I just did this thing for looks, I'll admit it. Oh, and it adds 25 whp too
Old Aug 31, 2004 | 03:49 PM
irish44j's Avatar
retired moderator
I got the idea from this guy, who I believe is/was on the org at one point and his car was set up for show....he did alot more work than I did, needless to say..
Old Aug 31, 2004 | 06:02 PM
irish44j's Avatar
retired moderator
by the way, does anyone know what that thing on top of his battery is?
Old Aug 31, 2004 | 06:07 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
those are distributors for amps, at least the left one is with MIDI fuses for each.
Old Aug 31, 2004 | 06:38 PM
spirilis's Avatar
oh geez... this is just over the top... I need to do it sometime
Old Aug 31, 2004 | 07:28 PM
ZIPPIN's Avatar
Mauja He Mauja
i am just not feeling it....
Old Aug 31, 2004 | 07:35 PM
spirilis's Avatar
You should make a similar cover that bolts onto the spare bolt threads near the intake manifold and valve cover...
although I dunno how acrylic holds up to intense heat... or what it would do if it melted all over the wiring
Old Aug 31, 2004 | 07:38 PM
irish44j's Avatar
retired moderator
not exactly what I had in mind...but it's a start. to do it the way i want to do it, would take more $$ and more time, both of which I don't have at the moment. This was the "prototype" so to say....second attempt (maybe this winter) will be alot cleaner.....
anyways,not looking for any "props" on this and if ya don't like it, fine by me....I'm just trying to throw some new ideas out there - seems like the org is getting a little short on interesting ideas recently.....every thread is talking about rotors or MAF these days.....
Old Aug 31, 2004 | 07:43 PM
Pepsiman's Avatar
w00+! i don't know if i would do this, but i love to mod! and i'm extremely efficient at it! i just haven't utilized my skill3z 100% towards my car. maybe one day i will, and irish will have some competition! ... (just messing irish) so for, the most i've modded was my grille. check out the sig! btw, tops up to ya irish! looks clean, and most of all, it's free! awesome!
p.s.
oh yeah, i have an injen intake, and i have huge openness right behind my battery... :\ need to do something w/ that.
Old Aug 31, 2004 | 07:54 PM
spirilis's Avatar
This is actually a fine way to post all your "stickers" without it being blatant ... just put it on this little "trim cover" under the hood!
Old Aug 31, 2004 | 07:59 PM
irish44j's Avatar
retired moderator
that's exactly what I was thinking.....only time people would see the stickers is when at a meet or at the track with the hood open, not plastered all over the car like I'm in NASCAR or something In fact those stickers I stuck on there just for the photo (to give definition to the piece) - they're actually ski company stickers and I took em off already...gotta dig around for my falken, stillen, apexi, etc.. stickers that are in a drawer somewhere (?)
Old Sep 1, 2004 | 09:26 AM
PearlWhtMaX2000's Avatar
Irish u are always comming up w/ something, but i like the cover gives the engine bay a nice clean look. good work
Old Sep 1, 2004 | 01:28 PM
Cutler's Avatar
Josh you should now add some gutter spouts on the side and have them run off the rain gutters from the roof...... You are Mr. Home Depot
Old Sep 1, 2004 | 01:31 PM
SoonerFan's Avatar
Cletus
IDEA STEALER!! i told you i was working on something like that and you stole it. IM SUING
and mine will look better you all will see. i have "prototypes" but im not posting anything till it is done.
i wanted to do it to clean up the engine bay. kinda like most german made cars where all you see is the top of the engine. plus i can put the stickers i have (warpspeed, etc)
plus in the future if i get any "performance goodies" they will be hidden
Old Sep 1, 2004 | 02:36 PM
irish44j's Avatar
retired moderator
except that other pic I posted above is the guy who did it first, donkey I always hear about prototypes from you but never seem to see the finished product...hey do you have the sticker from the T-shirt mod
And as for you, Mr. "I drive a 2004 Accord Sedan Bone Stock And Can't Figure Out The Navigation System, But When I'm Not Driving My Accord I Drive a Pink Sentra".....Jason and I were discussing getting a huge erector set tail for your pretty new accord
Old Sep 2, 2004 | 05:25 AM
2k3TitaniumSe's Avatar
I like it. Nice job. And it looks really clean.
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Redfox
Sep 28, 2015 10:41 AM
