pedal reset
Old Sep 1, 2004 | 02:38 PM
Maxnut's Avatar
pedal reset
There was a thread a couple of days ago that showed how to reset the gas pedal. I cannot find that thread now. Can anyone give me instructions on how to reset it in an 03?
Thanks.
Old Sep 1, 2004 | 03:03 PM
edgenuts's Avatar
Maxnut, here's the link: http://www.technosquareinc.com/350reset.htm. The exact same instructions are under the sticky "How-To" topic.
Old Sep 1, 2004 | 05:35 PM
edgenuts's Avatar
Uh, this works... I just did it. It took me a butt load of tries but I finally got it with a little POS stopwatch. Damn that's nuts, no more SES light!
Old Sep 1, 2004 | 07:21 PM
Maxnut's Avatar
thanks for the link. How can you tell if the reset worked or if it needs to be tried again.
Old Sep 1, 2004 | 07:39 PM
CRBWS6's Avatar
forgive my igorance, but could someone explain the reason for this doing this procedure? thanks.
Old Sep 2, 2004 | 04:25 AM
edgenuts's Avatar
Maxnut, oh crap, I gave instructions for an ECU reset... My fault.
Go here: http://forums.maxima.org/showthread....85#post2389185
And scroll down a little and you will see the gas pedal reset procedure. It's below the ECU reset procedure. The instructions say '02 but it should work in an '03.
Again sorry about that, I didn't meant to mislead you.
Old Sep 2, 2004 | 06:09 PM
Maxnut's Avatar
No worries, I appreciate the info.
Old Sep 4, 2004 | 08:41 AM
sleotta's Avatar
what is the purpose of the ECU reset? what does it mean when you say "the car gets used to the way you drive"? if my ECU hasnt been reset does that mean that my car is still "used to" the old driver? can it be "retaught"
clearly im confused about this whole concept
Old Sep 5, 2004 | 07:05 PM
rule da road's Avatar
On my 2000, nissan tek said it'll learn as u drive. My guess is reset is only good if u cant wait. It'll pick up mods by itself.
Old Sep 6, 2004 | 12:23 AM
glemax01's Avatar
sounds good
Old Sep 7, 2004 | 05:53 AM
sleotta's Avatar
:::: BUMP ::::
no one answered the question i asked a few posts up.....
QUOTE :
Old Sep 7, 2004 | 09:58 PM
ok well, i got my ecu scanned. never had it reset/reprogrammed. And u know what, not a single code. Thought my intake would set it off but no.
Old Sep 7, 2004 | 10:24 PM
mdloops's Avatar
To answer the question of the reset:
It is recommended to reset you ECU after a performance modification to the car so the car learns more quickly to sense different amounts of air flow. Newer cars do this automatically after a little bit of time (from my experience a couple of weeks). The reset just makes the process happen a little quicker. A car will learn and relearn as you drive. The ECU reset is a bigger deal for mods such as cams or lower engine buildup. I personally don't think it is necessary to reset the ecu after every little modification. Some people like to reset their ecu after adding an interior trim kit
In short, if you talk to any tech they will tell you that the car will relearn airflow rather quickly. Newer cars have so many sensors now that they can tell when you pass wind A lot of people are just dying to get a hold of that extra .0038 HP
Hope this helped,
Mark
Old Sep 8, 2004 | 08:26 AM
KCMC582's Avatar
i understand the point of the ECU reset, but what is the point of the pedal reset?
Old Sep 8, 2004 | 11:05 AM
sleotta's Avatar
thank you MDLOOPS.... finally someone knows whats goin on
Old Sep 8, 2004 | 05:10 PM
mdloops's Avatar
Not a problem. I have been modifying cars now for a few years and have seen much research and every car club has the some people who believe myths such as : You stock ECU will not adjust for new incoming air flow, your stock ECU NEEDS to be reset in order for your sensors to pick it up, etc...
Hope the info helps guys,
Mark
Old Sep 8, 2004 | 08:46 PM
mdloops's Avatar
MYTH : All Factory EFI Systems Are Crap...
Ahh yes, the old "as soon as you change (insert mod here), you must change the computer" drivel. The fact is, every EFI car made within the last 10 years has a self-learning capability and the scope for extra power built into its factory ECU. Most cars can make up to around 20 percent more power before they start to encounter ECU problems. And cars with mass airflow meters are even more tolerant of an increase in power. Sure, a fully-mapped system to suit a specific engine is the optimal set up, but it isn't the be-all-and-end-all for most of us. In most cases, modifications to the factory management can give effective results for very little cost.
Then we can spend the money we save on some of those "fashionable" moo-cow seat covers...
Thought you guys may like this. Taken from autospeed.com
Old Sep 9, 2004 | 12:37 PM
KCMC582's Avatar
guys, i hate to bump this up and ask again, but i still dont understand the point of the pedal reset. ECU was to make the car start learning again from scratch, but what does the pedal learn? does it know how you hit the gas and whatnot? sorry for the newb question, its only been a week of ownership
Old Sep 9, 2004 | 01:09 PM
juice's Avatar
2k2 and up utilize a drive by wire system. The pedal reset procedure will reset the fully depressed and fully pressed positions of the pedal.
Old Sep 9, 2004 | 01:45 PM
mastah's Avatar
and the point of reseting the fully depressed and fully pressed positions of the pedal is?
Old Sep 9, 2004 | 02:13 PM
gxe2se's Avatar
Does the Pedel reset work for 00-01
I want to reset my 2000 gxe to RELEARN the shifting. the previous owner was a little gentle, and my automatic shifts gently too.
input would be appreciated. I am not complaining , just wanted to know if relearning is possible.
Thanks,
-Anthony
Old Sep 15, 2004 | 07:41 PM
KCMC582's Avatar
just a quick question about the reset procedure, then we can let this thread die...
after turning the ignition switch OFF for the second time, and waiting at least 10 seconds, what do you do? start the car? remove the key? i just wanna make sure i do it right, and there is no step after that. thanks guys
Old Sep 17, 2004 | 06:04 AM
KCMC582's Avatar
bump...can anyone tell me what the final step is? start the car or remove the key?
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
