resetting the TCM
Old Sep 1, 2004 | 07:54 PM
Maxnut's Avatar
resetting the TCM
I was reveiwing the faq's and saw the reset for the TCM. I am currently having minor problems with my tranny. The car shifts moderatly hard and the shifts last about twice as long as they should (best way I could think of to describe symptoms). Will the reset help me? Is it possible if I do the reset I may cause more problems?
Old Sep 2, 2004 | 07:19 AM
RAZORFISH228's Avatar
Did you try changing your Tranny Fluid with Mobil 1 syn first before doing the reset?
Old Sep 2, 2004 | 09:29 AM
mdloops's Avatar
I would not recommend changing your tranny fluid other than perscribed intervals on an ATX. An automatic needs a specific consistance of tranny fluid and friction in order to shift properly. If you change your tranny fluid improperly your transmission will slip. Also if you change it you need to add an additive that promotes grip. I believe this additive is called a "friction modifier".
Old Sep 2, 2004 | 02:08 PM
SoonerFan's Avatar
Cletus
you CAN NOT reset your TCM. you have to get a new one. mine is on its way. cost $430. standard price is $580
gigabyte
Jan 6, 2017 06:05 PM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 22, 2015 03:08 PM
vrajesh123
Sep 22, 2015 04:20 AM
Colossus
Sep 9, 2015 05:46 AM
