Install Instructions on Hella Horns?
Old Sep 2, 2004 | 04:23 PM
ZIPPIN's Avatar
Mauja He Mauja
Need some direction how to install them. I have the Hella Super Tone, made in germany. There are 2 horns in the box. I have read that they are plug and play. But it doesn't seem like that. before I go ripping out wires, has anyone installed them?
Old Sep 2, 2004 | 04:34 PM
irish44j's Avatar
retired moderator
yes...totally plug and play. unplug the 2 wires from each stock horns. Plug them into the hellas. You don't need to use the included relay. The hella brackets fit perfectly into the OEM mounts.
you can install the horns in the factory locations (1 behind the grill and one on the passenger side of the engine bay) or do like me and mount both behind the grill (there are 2 mounting brackets there, but its a PITA to mount them because the grill clearance is so close...hope that helps.
Old Sep 2, 2004 | 04:36 PM
irish44j's Avatar
retired moderator
here you go, here they are in stock loactions, before I moved them:
Old Sep 2, 2004 | 04:43 PM
SoonerFan's Avatar
Cletus
you can just remove the grill to do it. its easy as hell to remove. i removed mine a few days ago to mount my tranny cooler
Old Sep 2, 2004 | 04:58 PM
ZIPPIN's Avatar
Mauja He Mauja
i moved back the protective sleeve, and i only see 1 wire. on the hella there are 2 places for wires to connect???
Old Sep 3, 2004 | 06:03 AM
ZIPPIN's Avatar
Mauja He Mauja
good morning. any input sooner??
Old Sep 3, 2004 | 10:41 AM
bsetiawan's Avatar
Good morning. There are no polarity to these terminals. Just connect the stock wire to whichever terminal and ground the other terminal. Click here for photos of the installed Hellas.
Old Sep 3, 2004 | 03:53 PM
irish44j's Avatar
retired moderator
yes...the other wire is just a ground, sorry I forgot. Just get some wire from radio shack and some crimp=on connectors and make yourself a ground wire and attach it at the grounding point - the closest ones are down next to the washer fluid reservoir neck...
Old Sep 3, 2004 | 05:14 PM
ZIPPIN's Avatar
Mauja He Mauja
thank you for the replies. watch out chicago cabies. get ready to get scared
Old Sep 3, 2004 | 05:15 PM
ZIPPIN's Avatar
Mauja He Mauja
thank you for getting those to me.
Old Sep 4, 2004 | 08:18 AM
ICELANDIC MAX's Avatar
good question zip. i am planning to do this mod sometime in the near future. great pics bsetiawan
Old Sep 4, 2004 | 10:13 PM
Audtatious's Avatar
Bandwagon Lover
Get a set of 350Z horns. I have the Hella's and while they are louder, I would much prefer a deeper toned horn instead of a high-pitched import tone. Of course, if you like it that way you should be golden...
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
