Scratching wheels or brakes
Old Sep 6, 2004 | 10:25 PM
ICULookN's Avatar
My front drivers side wheel is making a scratching/whistling noise when I'm driving, when I put my foot on the brakes, the noise goes away, when I let up off the brakes I hear the noise again, it sounds like something is scratching the rotor. Is it possible that my pads are wearing down, warped rotors, or something else? I run my fingers across the rotors and there are no grooves or ridges like something is scratching into them. I heard that our pads have like a prong that scratches the rotor to less us know when the pads have worn down too low, is this true? I order some new pads from DaveB to be on the safe side, is there something I should be looking into? Thanks for anyones help.
Old Sep 6, 2004 | 10:45 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Sounds like the wear indicators on the brake pads to me.
Old Sep 6, 2004 | 11:15 PM
MaximusLow's Avatar
happened to my car exactly that way...replaced pads...noise never went away...im about to change my rotors and see what the hell it is...ill let you know if it stops...
Old Sep 7, 2004 | 05:57 AM
darrelfsu's Avatar
Brake pads are worn. Mine was coming from the back; I was puzzled with the noise until i replaced my pads & then it went away. Now, its coming from the front. Its embarrassing; I haven't had time to get them replaced.
Old Sep 7, 2004 | 06:23 PM
ICULookN's Avatar
So there are wear indicators on our pads. I ordered some new f/r pads from DaveB earlier, less than $90 for everything. I will order some brembo rotors from maxedup in another month or so. Thanks for the advice.
Old Sep 7, 2004 | 07:43 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Originally Posted by ICULookN
So there are wear indicators on our pads...
On all brake pads...just FYI
Old Sep 7, 2004 | 07:53 PM
irish44j's Avatar
retired moderator
check the dust shield behind the rotors....there is not much clearance theere and if its slightly bent it will rub the back of the rotors and cause that noise....but it rubs lightly enough that it does not groove the rotors. bend it back slightly and see if it goes away.
Old Sep 7, 2004 | 10:33 PM
A33 VQ30DEK's Avatar
try bending back the heat shield...
Old Sep 8, 2004 | 05:48 AM
Igor911's Avatar
No NOT ALL
No wear indicators on Stillen or Axxis pads
follyburr
Detailing
Jun 13, 2016 02:06 PM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
16_SR
Sep 9, 2015 07:14 PM
dcam0326
Sep 8, 2015 11:02 PM
