Metal scratching sound coming from rotors...when breaks applied makes almost a hiss..
Old Sep 8, 2004 | 09:04 PM
MaximusLow's Avatar
What the hell can this be?...i changed my pads and cut the rotors...it got LOUDER!...what the hell...the problem started when i started to get vibrations from breaking...so i cut the rotors and changed the pads...and it go louder...but vibration went away...anyone know what it can be?...
Old Sep 8, 2004 | 09:10 PM
mistermax's Avatar
brake pad shimmy
Old Sep 8, 2004 | 09:37 PM
MaximusLow's Avatar
what do i do to fix it....the noise is embarassing
Old Sep 9, 2004 | 03:28 AM
panda_1's Avatar
that means its time for a change of brake pads.
Old Sep 9, 2004 | 03:30 AM
panda_1's Avatar
also does your car shake when you apply the brake? if so its time for either a replacement of rotors or the cheaper route would be to get them cut.
Old Sep 9, 2004 | 04:07 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Time for new break pads............
Old Sep 9, 2004 | 04:11 AM
vqman
would you guys please read his post..
he just replaced his pads and turned his rotors and it got worse..
-vq
Old Sep 9, 2004 | 04:39 AM
dvanorder's Avatar
Did you replace with a higher performance pad? If so, they tend to be noisier during street driving but get quiet during autocross. I haven't changed my Max pads yet, so I don't know if they come with the anti-squeal shim on the back. If they do have shims, it's possible that's what's causing it--was silicon used during install?
Old Sep 9, 2004 | 07:24 PM
MIXXMAX's Avatar
First, you must tell us what KIND of pads you are running with. This can help us help you with your problem. Like someone said before, those high performance pads are notable for squealing noises. Do what I always do, buy NISSAN pads. You never go wrong with them.
Old Sep 9, 2004 | 07:58 PM
foodmanry's Avatar
Da Roller Coaster!
Need to install shims with your new pads.
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
follyburr
Aug 7, 2015 09:50 PM
Jcof88
Aug 3, 2015 10:43 PM
