ABS Light ANd Steering Vibration HELP!
Old Sep 9, 2004 | 07:30 AM
saj07's Avatar
Hi I have 2 problem
1. I recently change my tires on my 2001 Maxima SE at 60,000 miles. Soon after that i noticed vibration on my steering wheel when i drive at 60 mph Please advise what to do not warranty. I saked Peb Boys who change the tire and they sadi we did not do anything to the steering, He rebalnce my tires but still the steering whell is vibrating. Need Help.
2. ABS light came on this morning i change my brake oads and skim the rotors 3 months ago Please advise
Old Sep 9, 2004 | 07:33 AM
Zero Deuce SE's Avatar
They probably overtorqued your wheel lug nuts when they put the wheels back on. That could cause the rotors to warp and also result in your vibration. Does your pedal pulsate when you apply your brakes?
Not sure about your second problem unless somebody disturbed a wheel speed sensor when the wheels were off.
Old Sep 9, 2004 | 07:35 AM
saj07's Avatar
No brakes is fine when i stop i have no problem. Please advise
Old Sep 9, 2004 | 07:43 AM
Try switching the wheels from the front to the back and see if the problem follows. If it does, the problem is in the tire/wheel balance. Also make sure that all the front lugs nuts are tight from the tire change.
Old Sep 9, 2004 | 08:42 AM
saj07's Avatar
Thanktoy but pep boys did that so they say?
Old Sep 9, 2004 | 10:03 AM
Unless you saw them do it, they may have just told you that to get rid of you. I would try it for myself so I can eliminate that possibility. I wouldn't let Pep Boys work on my lawn mower.
Old Sep 9, 2004 | 10:13 AM
saj07's Avatar
Thanks but i can not change 2 tires at once, I will check the torque on the wheel manually. Any other suggestion. I want to take it to the dealers but i have no warranty.
Old Sep 9, 2004 | 02:31 PM
saj07's Avatar
I am going to pep boys again see what they can do re balance let you know what happens.
As far as ABS well it went off so i suppose i will not worry right now.
Thanks everyone
Old Sep 9, 2004 | 04:49 PM
schernov's Avatar
As far as vibration - I 99.99% gurantee you that they did not balance them right. Ask them to rebalance ALL of them to 1/4oz on the Roadforce machine. I had to go 4 times back when I got new tires. They went thru 12 tires to finally find 4 that did not vibrate (Continental).
As far as ABS light - it might be that you have a loose connector to your ABS sensor. Connectors are located on the inside of the frame in the back and near the weel up front. Check them...
Yea, and toque your lugs to 80lb ....and not with air-wrench. warped rotors come into play only when you apply brakes...if they are warped-it will shake a lot.
Old Sep 10, 2004 | 07:46 AM
saj07's Avatar
Ok Thankyou everyone finally they fixed it, I insisted pepboys to re balance and rotate all four tires, And i told them to reverser the tires from the back to the front and front to the back. I insisted i watch them do it they said it will take 2 hours i said i have 24 hours. SO i watch them balance & Rotate and guess what the problem is gone. SO the conclusion is they did not balance or rotate when they said they did twice. Thankyou everyone for your kind help/
Problem 2 ABS well I figured it out it never did that but when i turn the key upto all the light come on but nit starting the engine ABS light comes on I see my brake pedal depressing like hydraulic turned on. then i turn off completely and turn back on but not starting the engine the ABS light comes on for 2 seconds then goes off. I was reading the manual and it says that is normal so i guess i will turn it on wait till the brake pedal depress, turn it off turn it off and abs goes off.
AnsonJ
Jun 2, 2017 01:35 PM
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
02nissmax
Sep 5, 2015 01:50 PM
tnewbs
Aug 28, 2015 10:15 AM
