Car wont start?????????????
Old Sep 12, 2004 | 05:47 AM
Akkord29's Avatar
Its a 01 GLE, the car at first would try to start then i thought maybe a jump would help, but when i try and start it with the cables on i get no response at all from the car likes it dead. When i take the cables off i started to get the clicking noise.
Is this the battery, alt, starter??
The power seats moved and the radio turned on, so there must be a little juice left. When locking the car the horn sounds very dim.
Its stuck in a parking lot right now so any insigh would help thanks.
Old Sep 12, 2004 | 06:30 AM
Ammi's Avatar
350 Detroit Muscle
Sounds like your starter is gone bad
Old Sep 12, 2004 | 08:29 AM
scopium
take something and bang the starter a bit.. then try again..
this is a wierd problem..
it happens to mine to but the dealer cant "duplicate" the problem to fix the damn thing
even though i tell them ITS THE STARTER
Old Sep 12, 2004 | 12:33 PM
MistaDJ's Avatar
Did you hook up the negative jumper cable to the battery or ground?
Old Sep 12, 2004 | 01:14 PM
Ka$hThaRipper's Avatar
wait, before you mess with teh starter...
take out your battery, and put in a brand new one and then try to start it
i have a 2000 GLE and i had the EXACT same problem less than 1 month ago -- it was the battery (and it wouldn't start even with cables).
Old Sep 12, 2004 | 01:38 PM
Akkord29's Avatar
i jump to both terminals, didnt try grounding it else where.
E55AMG2's Avatar
Wat
sounds like you had the cables on backwards when you tried to jump it, and that your battery is dead....
Old Sep 12, 2004 | 01:39 PM
Akkord29's Avatar
cables were right i tried 2 times.
Old Sep 12, 2004 | 01:43 PM
E55AMG2's Avatar
Wat
If that is the case, ground the negative cable and try it again. I def think the battery is gone
Old Sep 12, 2004 | 01:51 PM
^^ what he said...
try a different battery altogether, it shoudl work
Old Sep 12, 2004 | 04:41 PM
Akkord29's Avatar
anyone know how to pull the alt fuse out. It is attached to the positive terminal.
I tried to pull up but it started breaking. And yes i somehow managed to blow the fuse.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
