how do i remove the map light bulb?!
Old Apr 8, 2001 | 02:40 PM
DooBall's Avatar
its driving me crazy. i cant remove the bulb!
its in some wierd setup, and ive pulled, pushed, etc, and it wont come out!
any help?
Old Apr 8, 2001 | 03:44 PM
areX's Avatar
any help?
it's pretty simple. push and turn clockwise. that's it.
Old Apr 8, 2001 | 04:05 PM
max2kgle526's Avatar
And try looking in the Owners MAnual. I was reading about Light REmoval 2 day.
Old Apr 8, 2001 | 05:35 PM
DooBall's Avatar
FINALLY! it worked.
thanks
Old Apr 8, 2001 | 07:24 PM
MaxSEAE's Avatar
what are you tryen to remove?
Old Apr 8, 2001 | 08:43 PM
RcticMax's Avatar
any help?
How many Maxima.org members does it take to remove a dome light?
Old Apr 8, 2001 | 08:55 PM
areX's Avatar
hahaha... i feel like a bunch of pol's... no offense... heheh.....
Old Apr 8, 2001 | 09:04 PM
RcticMax's Avatar
Hey areX - I noticed in your signature that you've changed every bulb except for the glove compartment and license plate. Does that mean you've changed the dome light too?
Sorry. I'm bored to tears. Can you tell?
Old Apr 8, 2001 | 09:21 PM
areX's Avatar
hahah.. yep. did that too. if you're looking to replace them with Polargs, get the Polarg M-16. they're 10w and come in a pair. perhaps you can share this with someone you know.
yes.... i'm pretty bored too... i've been on the forum aLL day... now i know how Kev and all the other guys feel... this is sick....
Old Apr 8, 2001 | 09:28 PM
RcticMax's Avatar
You know it's really slow when the top 5 messages have your name in the last posted column... for ten minutes straight!
Is it bedtime yet?
Old Apr 8, 2001 | 10:06 PM
areX's Avatar
Is it bedtime yet?
bedtime?!?! it's 10pm in California!
Old Jan 15, 2011 | 07:32 PM
jharnarain's Avatar
Map bulb went out, changed and and it came on for a brief moment, but now will not work at all. The dome light is not working either, as well as the interior door lights, the power locks will not work unless the key is turned on, and the homelink system seems to have no power and will not work, and lastly the remote entry will not work. Checked the fuses, and there was one that was bad, replaced it, and still none of these work. Any suggestions?
Old Jan 22, 2011 | 02:34 AM
zzmmrx0xmzz's Avatar
Pretty sure its the fuse. How did you check? You need to use a device to check if the fuses are still good, looking at the fuses doesn't always work. I forgot what it was called but they can be found at any hardware store. BTW this thread was past 10 years old till you bumped it up.
mvm062
Nov 30, 2020 09:00 AM
iflexsteel
Sep 15, 2015 03:37 AM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
umnitza
Sep 1, 2015 01:03 PM
