Interior lights
Old Sep 14, 2004 | 09:30 AM
BlackFlux's Avatar
Interior lights
Since I can’t do a search, has any one heard of someone changing all of their interior lights to blue?
Old Sep 14, 2004 | 09:53 AM
khynex's Avatar
BLKMAX95C did that in blue leds I wanna try 2 do it myself this weekend but w/ white leds
check them out here http://www.cardomain.com/memberpage/479058/3
Old Sep 14, 2004 | 10:03 AM
Progress's Avatar
It's business time.
Check irish44j, he has some pics on his cardomain.
Old Sep 14, 2004 | 12:17 PM
BlackFlux's Avatar
irish44j's solution seems the be easy. I would like to see what it looks like in the daylight before I mess with that.
Maybe I'll try that. Is he using a blue sharpe?
Old Sep 14, 2004 | 01:11 PM
khynex's Avatar
can i get a link to irish44j page?
Old Sep 14, 2004 | 02:46 PM
BlackFlux's Avatar
http://www.cardomain.com/id/irish44j
Old Sep 14, 2004 | 04:46 PM
ICELANDIC MAX's Avatar
pmas76 has nice write up too:
http://www.cardomain.com/member_page...224200&page=13.
Old Sep 14, 2004 | 08:07 PM
irish44j's Avatar
retired moderator
yeah the method I used was fairly easy...sharpie in 3 places:
-contact patches of the clear plastic light transmitter thingy (you'll know what I'm talking about if you take it apart.
-colored (3 coats) clear transparency film cut to fit in front of LCD displays
-colored inside of buttons (be careful, they are easy to break the tabs off when removing).
oh, don't forget to take the blue/green "condoms" off the bulbs. If you leave them on it will be too dim.
The only downside I've found is that the blue on the buttons and plastic grid will fade over time (no surprise) so every 3-4 months I take it apart and add another coat of blue to get the deep blue color back....
Originally I did 4 coats on the transparency film, but found it was too dim in sunlight and bright days. I just took it apart again this week and put new transparency film in, with only 2-3 coats. It now shows up fine in the day and at night. Color is "slightly" more greeninsh than in my cardomain pics, but is still blue, not turquoise....
Old Sep 15, 2004 | 05:41 AM
khynex's Avatar
u guys know of any autopart stores that sell the small leds?
I wanna see if I can buy them so I can do this project this weekend
Old Sep 15, 2004 | 07:49 AM
Pri63's Avatar
I recommend getting them from Ebay...i don't you can beat the price...I've almost completed the blue conversion in my car...all blue LED's...I'll post pics once it's all complete.
Old Sep 15, 2004 | 07:52 AM
khynex's Avatar
Im gonna go w/ ebay if I cant find them this weekend, Im just trying to find some around MIA so I can put them in saturday
Old Sep 15, 2004 | 08:00 AM
silvermax2k2's Avatar
changed everything to blue by replacing all the leds to blue. there is no way the i'd be willing to take apart everything and color it in with a blue marker every 4 months... thats just retarded. (no offence) if your going to do something, do it right.
-Chris
Old Sep 15, 2004 | 08:18 AM
khynex's Avatar
Blkmax95c did u use 5mm led bulbs or where urs a different size
Old Sep 15, 2004 | 08:55 AM
all leds were 5mm in size, and 6000mcd for brightness. viewing angle is 15-20 degree's, 3.3 -3.5 v. make sure you use a resistor.
Old Sep 15, 2004 | 09:56 AM
khynex's Avatar
what resistor u used ?
Old Sep 15, 2004 | 10:17 AM
Pri63's Avatar
330 ohm 1/4 watt you can pick them up at radio shack...are you trying to convert your stock radio to blue also?
Old Sep 15, 2004 | 10:23 AM
khynex's Avatar
no I just want 2 do the guages hyper white and the window buttons hyper white also, but all that soldering crap i hate so i dont know if im gonna do it over not
Old Sep 27, 2004 | 11:37 AM
BlackFlux's Avatar
irish44j, what if you spayed a clear coat over that "plastic light transmitter thingy?" Then you wouldn't have to re do it every few months?
Old Sep 27, 2004 | 02:33 PM
irish44j's Avatar
retired moderator
possible...but I'm not sure if that would help with the color fading...it's not rubbing off, the chemical makeup or whatever of the ink just fades from light....
Old Sep 28, 2004 | 02:40 PM
BlackFlux's Avatar
Yeah but a clear coat would be spray paint so it shouldn't fade at all. The only way spray paint will fade would be if you kept touching it. I think this is a solution that would solve your fade problem.
Old Sep 28, 2004 | 07:06 PM
Bl_asd's Avatar
how to use resisitor? connect one side of led bulb to 1 side of resistor and the other side to power( those pins) , and connect the other side of resiistor to power (pins)?
Old Sep 29, 2004 | 05:56 AM
solder on the resistor to the "positive" side of the led leg. the positive side is the one with the smaller diode. (if you look in the led, you will see two metal contacts. smaller is the positive one)
gl.
Old Sep 29, 2004 | 06:21 AM
custommaximaSE's Avatar
For the guages ,i bought #74 led bulb from http://autolumination.com/
It make my guages glow bule (It fit perfect,real nice blue color)but i dont want the blue color.I already did every thing else hyper white.Since im doing the hyper white converion.
Could someone please post a link for a clear guages.ill post pics when im done.
thie is the super white led the one i bought.
Maximan190
Dec 16, 2015 06:01 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
