Changing Color of Clock/AC
Old Sep 16, 2004 | 04:29 PM
JC_2k_SE's Avatar
today i changed the color of my stock head unit to light up blue instead of the normal green. does anybody know how to change the color on the AC controls on an 01 as well as the clock? thats the only parts i couldnt get.
Old Sep 16, 2004 | 04:37 PM
irish44j's Avatar
retired moderator
you mean like this?
they should come apart as the same assembly.. The climate control has 4 small silver screws on the back that you have to take off, and black plastic clips on the top and bottom lip....then you do it the same way...
more pics on my webpage...sorry they're so small.
Old Sep 16, 2004 | 04:39 PM
irish44j's Avatar
retired moderator
for the clock you just pop the assembly out the top of the dash and it's piece of cake from there....
Old Sep 16, 2004 | 04:46 PM
JC_2k_SE's Avatar
yeah irish, i used your pics as a guideline and they were a big help but i couldnt understand why my AC controls are different from yours. i dont have a digital display, just a ****, the slider to adjust hot/cold, and a few preference buttons
Old Sep 16, 2004 | 04:59 PM
Bl_asd's Avatar
b/c you have a manunl control instead of auto one....same as mine... can you open it up and change to blue bulb? so the bottoms light up as blue at night instead of greenish white
Old Sep 16, 2004 | 05:22 PM
irish44j's Avatar
retired moderator
you don't need to change the bulb necessarily...you can still color the inside grid and backside of the buttons for the same effect....
Old Sep 16, 2004 | 05:31 PM
JC_2k_SE's Avatar
i think im just gonna take it apart again tommorrow and see what i can do about gaining access to the display... Bl_asd ill tell you the results after i do it
Old Sep 16, 2004 | 06:09 PM
Bl_asd's Avatar
i know..but will the white part of the bottom look bluish from outside?
Old Sep 16, 2004 | 07:37 PM
Epacy's Avatar
Unsuccesful STL Coordinator
The bulbs on the manual control are not your regular instrument bulb 74. They are different bulbs with the wires coming out the back and wrapped around a small gray screw-in holder. The contact is made with the circuit board and the wire that is wrapped the holder. Not sure what type of bulb those are. Would like to find out cause they need to match the rest of my interior. As far as the light that shines down on the console, it is a bulb #74. I did have a blue incadescent bulb in there before but the thing barely shined. I ordered some blue leds with the flat top-so most of the light comes out the end, and cut out the center piece of plastic between the two openings. The blue led is crazy bright and shines perfectly on the console. A 200% increase over the regular incadescent bulb.
Old Sep 16, 2004 | 08:17 PM
Max_N_Action's Avatar
hey 0eric2,
where did u buy the #74 led bulb...dont c any on ebay...thanks
also do u have any pics of urs installed?
Old Sep 16, 2004 | 08:52 PM
Epacy's Avatar
I got the incadescent and led #74 bulb from http://stores.ebay.com/CTLumination.
I don't have any pics, unfortunately I don't have a digital camera. I really wish I did.
Old Sep 16, 2004 | 09:23 PM
they seem to not have any 74s anymore...o well thanks anyway
Old Sep 16, 2004 | 09:57 PM
Epacy's Avatar
Nope, here is the link. http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Sep 16, 2004 | 10:06 PM
Gennady7's Avatar
Hey irish44j
where did u get that blue tape to put on top of the green lighting lcds
Old Sep 16, 2004 | 10:10 PM
thomasd cook's Avatar
I have pics of LED's in the manual AC controls on my homepage. I sautered LED's with resistors directly to the board. I finally finished all my lighting with led's. By the way what color of plastic wrap is used to change the clock to blue?
Old Sep 17, 2004 | 06:17 AM
ZIPPIN's Avatar
Mauja He Mauja
this stuff scares me
Old Sep 21, 2004 | 10:58 PM
glemax01's Avatar
i should try it...
Old Sep 22, 2004 | 11:08 AM
Bl_asd's Avatar
ok..i opened up my A/C (nonclimate control) so i have 3 little bulbs...how do i take them out of the grey screw holder? i have to bend the wire in order to take them out? this is really difficult to discribe without pic ...sad i don't have digi cam...
Old Sep 22, 2004 | 02:06 PM
SoonerFan's Avatar
Cletus
Originally Posted by Gennady7
Hey irish44j
it isnt blue tape. its the thin plastic for overhead slides painted blue with a sharpie
Old Sep 22, 2004 | 02:33 PM
irish44j's Avatar
retired moderator
yep what sooner said...
Old Sep 22, 2004 | 05:53 PM
Epacy's Avatar
Just unscrew those holders. They come out in about half a turn. And yes, you do have to remove the wires for the bulb to come out. Tell me if you find somewhere that carries those bulbs.
Old Sep 22, 2004 | 05:58 PM
s_hinerman's Avatar
Is there a how-to for changing all the lights out on anybodies page??
Or if anyone has any info please let me know
Old Sep 22, 2004 | 06:03 PM
Progress's Avatar
It's business time.
Me too, it looks really hard to me but I want to do it anyways for the look. It looks like a pretty intense process.
Is there an alternative to getting clear plastic and painting it blue?
Oh and does the blue in reality look factory or ?
Old Sep 22, 2004 | 06:33 PM
Bl_asd's Avatar
ok as i thought..I removed the little bulb out...also took of the condom. There's one thing i found out that the little bulb with condom is as thick as 74 bulb. the difference is that 74 bulb has plastic wrapped the wires from the fliment but the little bulb don't. I'm thinking maybe we could make 74 bulb fit in the screw socket by cut off the plastic on the bulb and make the wires move freely as the little bulb. Therefore, we could use 74 bulb in the socket and lit up our bitXh A/C. It's gonna be kind of difficult since bulb is too small to cut nicely....should I be the guinea pig?
Old Sep 22, 2004 | 06:42 PM
silvermax2k2's Avatar
a lot more pics on my page found here: http://www.cardomain.com/memberpage/479058/8
Stagnet04
Sep 14, 2015 11:28 PM
minsbang
Sep 11, 2015 08:48 PM
MplsMadMan
Sep 11, 2015 07:54 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
