Wiring front doors....HELP!
Old Apr 9, 2001 | 06:23 AM
DMAX
Okay I really need some help, I began to install my system over the weekend and everything was going fairly well till I got to the wiring of the front door speakers! What the hell set up is this in our cars? I have never seen the device that this car has to get the wires inside the cabin of the car. It looks like a rectangle block that the door wires plug into? Is this right? How have you guys with systems wired your front doors? PLEASE HELP!
Old Apr 9, 2001 | 06:33 AM
punkdork's Avatar
Three ways I can think of:
If you are using stock wiring, cut the harness out of your old speakers.
If you are re-wiring you can figure out some way to work the wiring through the existing conduit.
Or you can go like me and drill new holes and use some rubber grommets to keep everything nice n safe.
Old Apr 9, 2001 | 06:49 AM
DMAX
I am going to need to work new wire through some how, can't use stock! Drilling a hole isn't a bad idea on the passanger side, its the driver's side that has all the computer stuff in the way. I would hate to have to remove all that.
Did you try to remove the block I was talking about?
Old Apr 9, 2001 | 06:53 AM
punkdork's Avatar
Here's what I did the first time around. Now I have holes drilled.
http://www.punkdork.net/max/speakers.htm
Matt93SE
May 24, 2019 02:58 PM
melteye
May 16, 2016 12:02 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
