Ignition Coil
Old Sep 18, 2004 | 08:10 PM
igzy's Avatar
I Know Kwaliti
Ignition Coil
Recently I noticed a buzzing sound (noise) coming from the engine compartment when the car runs under load, e.g. when on an uphill and want to accelerate, taking off from a stop, etc. The noise goes away once I am cruising on lower RPMs but it always comes back when you step on it. The power is still there but the noise is annoying. It almost sounds as a slightly loose heat shield, but all exhaust parts are in place. I've changed the PCV valve (though I did not notice any variation in idle RPM prior to this), I put in new NGK Iridium plugs, car has only 60K on it and is 2K. It has the original old coils. Now, I am wondering, would a bad or a going bad ignition coil cause noise like this and can the coils be tested for functionality and how if so? Thanks...
Old Sep 18, 2004 | 08:18 PM
StillenMax80x20's Avatar
ignition coils go bad with the engine light on, a code reading "cylinder * misfire" (p030*)or "multiple misfire" (p0300) or "bad ignition coil" (p1320) accompanied with severly reduced power, possible stalling and or 'engine shakes'
peace
Old Sep 18, 2004 | 08:45 PM
ZIPPIN's Avatar
Mauja He Mauja
peace
^^that is incorrect. not always does a bad coil throw a code. this has been discussed many times.
Old Sep 18, 2004 | 08:47 PM
ZIPPIN's Avatar
Mauja He Mauja
is there any loss in power? ususally if the coils are bad and the plugs are changed, it will throw a code. it does not sound like the coils are bad. when did you change the a/c and alternator belts?? when you floor it, what happens?? does it "GET IT" or do you experience hesitation?
Old Sep 19, 2004 | 05:59 AM
igzy's Avatar
I Know Kwaliti
There are no codes set. The power is always there, no hesitation.
Hm, belts are a good idea! I think they are original. I'll change them both and see what happens...
Thanks for the suggestion and education on coils!
Old Sep 20, 2004 | 07:08 AM
igzy's Avatar
I Know Kwaliti
Another thought, sometimes the car does not start on the first key turn, it almost feels like it is starved. Then when I turn the key for the second time, with a small struggle, it does fire up. This happens at random, perhaps once a week. No particular pattern with regards to engine temperature... Would this be a related problem? I got the belts and will change them tomorrow...
Old Sep 20, 2004 | 07:15 AM
Ryans Maxima's Avatar
I have this exact same problem
Old Oct 6, 2004 | 04:15 PM
hankselke's Avatar
HMS
Anybody know how to fix the coils yourself?
Old Oct 6, 2004 | 04:30 PM
Love_00_Max's Avatar
You don't fix the coils - you would have to replace it altogether. Sucks when it costs $80.
Old Oct 6, 2004 | 04:33 PM
BLKMAX005SPD's Avatar
peace
NOOOOOOOO
Please no...i really don't want to replace my ignition coils!
somtimes when i start my car up it sounds like a WRX with exhaust...
Old Oct 6, 2004 | 07:36 PM
NYPD-Arnold's Avatar
Z
As far as the topic at hand: It's normal. Pefectly normal, in fact. If you have your Owner's Manual look at section 10, page 4.
Old Oct 6, 2004 | 10:39 PM
coils aren't hard to replace, it tells you how to remove them in your owners manual under removing or replacing spark plugs
Old Oct 6, 2004 | 10:41 PM
it took me 5 minutes for one bad coil, theyre just expensive, go to classifieds 5 gen forum and look for the thread on $235-$260 shipped for all six
Old Oct 21, 2004 | 01:52 PM
igzy's Avatar
I Know Kwaliti
"As far as the topic at hand: It's normal. Pefectly normal, in fact. If you have your Owner's Manual look at section 10, page 4."
Thanks Arnold. That's a valid point, however, I am running 94 octane gas in my car. Here is what I found: The starting problem went away after I cleaned the throttle body. I have not had a bad start for more than a month now. For the noise issue, I put in new NGK Iridium plugs, and replaced both belts and the noise was still there. Then I raised the car and checked all exhaust heat shields and found that one just before cat was slightly loose. A $1 clamp tightened it and guess what - the noise is gone. Thank you all for your contributions and have fun :-)
Old Oct 21, 2004 | 03:07 PM
NewLoveI30's Avatar
Ahhh the infamous heatshield rattle. Its been a while since I heard that one come up.
Glad you found it!
Old Oct 21, 2004 | 05:52 PM
Raf2kMax's Avatar
i have a similar thread in this forum but NO ONES RESPONDING!!! i just went to autozone..my car was shaking on an incident last week with the slip and tcs light on but recently no codes been thrown and no shaking/weird acceleration.
couple codes came up after teh comp was plugged in...P1320..and P0301-cylinder 1 misfire. p0740 - circuit malfunction also but that might be because of the 5 speed swap on the car...a whole lotta 5 speed swap related solenoid problems came up lol..
supposedly the 1320 and 0301 are both related to the ignition coils...but should i replace the one or all 6?? last three days when ive been starting the car, theres a noise coming outta the engine...it takes like half a second more to start and u hear like a zippp.. like what you hear when you turn the ignition when the cars already on!!! maybe cause of the faulty coil?? please help... need answers!!!
Old Oct 21, 2004 | 10:04 PM
thomasd cook's Avatar
I have the same problem also as the first guy. I did recently change my Y-pipe. I do have a SES light and had it pulled. It said it was a misfire but didn't pinpoint it. I changed the plugs reset the ECU and I still feel a random misfire and SES light. I'm going to try and get the code pulled again. I have a feeling it's my coils. I do notice a rattling sound when I punch it. But I swapped the Y-pipe and there aren't any more heat shields except over the cat.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
