Is my Tranny slipping? TSB advice.
Sep 20, 2004 | 01:36 PM
Hi im not sure if my car (2001 AE Auto) just acted weird or what. The otherday i pulled out of a parking long and put the pedal to the floor to take off up a hill. I normally dont drive my car hard, but my car did nothing. It was like a 5 second stall at 1000rpms then finally it shift and went, but it took way longer than normal. Then a day later it did something similar but not nearly as bad. Is this slippage? Anyone get the 1-2 slipping TSB? Thanks fellas
Sep 20, 2004 | 01:38 PM
i meant parking *lot
Sep 20, 2004 | 01:39 PM
yep tranny is on its way out
it should be fixed under warranty though
Sep 20, 2004 | 01:40 PM
could be alot of things.
did the RPMs stall? bad MAF, coil, spark plug, or dirty throttle body.
or did they keep going up but the car didnt go? tranny
Sep 20, 2004 | 01:42 PM
and no it doesnt neccesarily mean his tranny is going bad. could be a bad TCM like i had or selinoids.
check the TSB for all the info
Sep 20, 2004 | 03:26 PM
any site with TSB?
my first gear goes until ~5,500 rpm when i push the gas bad, do you guys think that i have bad MAF? im thinking that is my intake cuz i didnt clean it at all, i will do it tomorrow or Wednesday...
Sep 20, 2004 | 08:09 PM
if your maf was out.. you wouldnt be able to go past 2.5k
i dont think its your intake
Sep 20, 2004 | 08:11 PM
i asked somebody and told that is normal if i push my gas pedal hard... so its normal to change 5,500 rpm, he told me i would worry if i go slow and first gear goes until 5,500 rpm
Sep 20, 2004 | 08:33 PM
also try to do the samething w/the Traction control Off. cus that also causeshesitation.
Sep 21, 2004 | 10:04 AM
how do u cut the traction control off
i gotta se 2002 , do i even have traction control?
Sep 21, 2004 | 11:18 AM
yeah i think u would, if u are sitting in the drivers seat its a button to the right ofyour stearing wheel.
Sep 21, 2004 | 03:28 PM
i dont think i have a button.. maybe se's do not come with it?
