Anyone know how to disable the AUTO Headlight Function?
Old Sep 21, 2004 | 03:55 AM
ToYLeT902's Avatar
JET Speed Lab
Does anyone know how to disable the Auto headlight function?
Old Sep 21, 2004 | 03:58 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Turn the switch to "Off"
Old Sep 21, 2004 | 04:17 AM
spirilis's Avatar
lol...
Old Sep 21, 2004 | 05:26 AM
darrelfsu's Avatar
lol... I couldn't help but come in and read this thread.
Old Sep 21, 2004 | 05:50 AM
Anuj's Avatar
Old Sep 21, 2004 | 06:02 AM
redstradic's Avatar
i would like to know how to as well. i cant stand it. at dusk, i like to just drive around with my angel eyes on. i have to pass through the auto function first flashing my lights on for a sec.
Old Sep 21, 2004 | 06:04 AM
Hamy's Avatar
I fully understand what your talking about man, don't let these guys bust your *****. I too am looking for a way to get around the "Auto On" feature on the headlights. In other words just have them Off - Parking Lights - On. The Auto feature is bad for the HIDs if you turn your headlights "on" the whole way each time they ignite once when it hits auto then again when its switched to on. This kills the life of your bulb. IMO its a poor design by Nissan. Soooo in other words if anyone knows how to kill the auto on/off I'd be very pleased.
Old Sep 21, 2004 | 06:29 AM
2k2-blk-6spd's Avatar
I am also very interested in this. I hate having to "jump" past auto and HOPE to get to the parking lights one without going to full on or leaving it in the auto position to where the HIDs come on so if anyone can help, please do!
boondoxmax's Avatar
very poor design. auto option should be at the end not in the middle......
Old Sep 21, 2004 | 07:28 AM
brianc's Avatar
Turn your parking lights on before you start your car then no headlights will come on.
Old Sep 21, 2004 | 07:40 AM
Ryans Maxima's Avatar
ya beat me to this one... I agree.
Old Sep 21, 2004 | 07:56 AM
redstradic's Avatar
i do that most of the time. however, the other times i forget to do that. just would like a way to disable the feature all together since i dont need it.
Old Sep 21, 2004 | 08:16 AM
Anuj's Avatar
c'mon man, it's John
he did it to me so many times that I am allowed to do it to him
and also, last time I was here you were selling your car -- turned out for the better
Old Sep 21, 2004 | 08:55 AM
GaMax97GLE's Avatar
I think this question is dumb, but I'll give you my answer...
Since the AUTO function works by receiving information from the sensor on the dash that monitors outside light levels, why not try cutting that wire. If the sensor readings aren't being relayed back to the AUTO feature, there's a chance this may stop the lights from coming on when selected to AUTO.
Old Sep 21, 2004 | 09:35 AM
D Love's Avatar
If you do decide to go this route, I don't think that it would be a good idea to just cut the wire and hope for the best. If it were me, I would go to my car at about noon, turn it on, turn the **** to AUTO, and read the voltage the sensor is putting out. I would then check the voltage of the sensor when it is pretty dark outside (maybe in the garage with the lights out). This should ensure that you see all, or close to all, of the voltage swing for the sensor.
This way, when you cut the wire to the sensor, you will know if you need to tie it high or low to simulate daytime. Plus, you will know how high to tie it if you do in fact need to tie it high.
Old Sep 21, 2004 | 12:23 PM
dino0128's Avatar
I don't think cutting the wires is the answer. I manage to disable the auto function in my i35 by poping the sensor up from the dash, on the body of the sensor you can see 2 or 3 metal strips exposed. I took some aluminum foil, and a transistor from my led and connected all 3 strips, then held it all in place with a rubberband. Done this over 6 months ago, and still works.
Old Sep 21, 2004 | 12:37 PM
zourtney's Avatar
just drive with them on, they go off when you open the door anyways....
Old Sep 21, 2004 | 02:36 PM
02SEinStL's Avatar
Agreed - the only thing, IMHO, that is badly designed on the Max. That "flicker" is bad for the HID bulbs I have heard
Old Sep 21, 2004 | 03:27 PM
ToYLeT902's Avatar
JET Speed Lab
now i know why i dont come on the forums anymore, all the helpful people left.
Old Sep 21, 2004 | 03:42 PM
kieranlavin's Avatar
There's also a CHANCE you could have the headlights on all the time! Don't cut the wire. Depending on the sensor, it could want more or less resistance and by cutting the wire, you may swing it all the way opposite causing the headlights to be on if it were nice and bright outside!
To disable the function, there might be a relay or fuse that you could pull? I have no need or want to do this so I'm likely not going to be checking any fuseboxes tonight. Check it out if you like...
Old Sep 21, 2004 | 04:28 PM
spirilis's Avatar
I thought you were kidding when you wrote the post
Anyway, this is on a 2000 (used AlldataDIY, but I think they just copied this from the shop manual)
Cut wire going to terminal 10 on the Auto Light Control Unit if you can find it...
Old Sep 21, 2004 | 07:14 PM
808SE's Avatar
I've priced and sourced a stock headlight stalk. I'm in the process of trying to get one of my electrical engineer friends to change the switch so it goes parking-headlights-auto, instead of auto-parking-headlights. I figure it can't be too difficult to switch the order, but I don't know a whole lot about electrical engineering. The stalk is only about $70 so I think it's a doable project.
I'll keep you updated if I can get that friend of mine to do it.
Old Sep 21, 2004 | 07:27 PM
spirilis's Avatar
I wanna modify one of those stock headlight stalks to allow me to NOT dim the interior lights when it's in Parking light position, so I can have the parking lights & foglights on (w/ rewire) as a Daytime Running light without dimming the interior.
Never got around to it though. Please share any notes he might have!
Old Sep 21, 2004 | 07:52 PM
00Max00's Avatar
Some smart guys here already found the answer for resolve this annoying thing. Why not just prepare a flashlight in your storage box in the center console. Everytime you want to disable autolight just shot the flashlight onto the headlight sensor. Once the sensor receives enough light then the headlight wont on.
Old Sep 21, 2004 | 08:04 PM
spirilis's Avatar
lol, that's pretty ghetto.
Old Sep 22, 2004 | 12:10 PM
02SEinStL's Avatar
Just install a Chrysler stalk
For years they have allowed you to run fogs only, and there is also a detent at the top of the "brightness" travel that will keep the dashlights from dimming
Old Sep 22, 2004 | 12:34 PM
zourtney's Avatar
That's cool, because I like driving with my headlights on, but it makes the radio and clock near impossible to see, especially with sunglasses on.
Old Sep 22, 2004 | 12:39 PM
silvermax2k2's Avatar
thats why you cut the dim wire for the clock, and buy an aftermarket radio! no problem here with dimming.
and as for just turning on the fogs, you can do the foglight re-wire. I always cruse around at dusk with just my fogs and parking lights on.
-Chris
Old Sep 22, 2004 | 12:48 PM
Mr. Peabody's Avatar
On my 03 there is also a detent at the end of the "brightness" reostat wheel that allows the interior dash lights to stay on full even when the headlights are on. Don't know if it that way on earlier models.
The flashlight idea is not all that bad, afterall it beats lighting a candle & keeping it on the console.
Peabody
Old Sep 22, 2004 | 01:03 PM
spirilis's Avatar
yeah, if the Chrysler stalk was anywhere near remotely compatible, which I doubt it is... no thanks
gavin68
Sep 18, 2021 12:36 PM
doctorpullit
Oct 28, 2019 10:58 PM
BobTX10
Oct 7, 2015 08:43 AM
Noela
Sep 26, 2015 08:22 AM
