MAF Sensor Replacement - Instructions?
Old Sep 21, 2004 | 12:09 PM
fatboyp's Avatar
I'm expecting my new MAF to arrive shortly and I'm not sure if I should try and install it myself or just take it to Nissan to do. For those of you that have replaced your own how hard was it and are there any instructions available that detail each step?
Is resetting the ECM part of the procedure and if so can you do that yourself or does Nissan have to do it?
Old Sep 21, 2004 | 12:52 PM
Love_00_Max's Avatar
On the top of the MAF is the connector -- unclick it. Take a phillips screw driver and remove the two screws and the sensor comes off. Put the new one into the slot and connect the connector. Unconnect batteries for 1 hr and reconnect -- if needed (I would think no!!!) you may/may not have to reprogram the ECU.
Old Sep 21, 2004 | 12:54 PM
Progress's Avatar
It's business time.
Are you getting the sensor itself or the whole unit (sensor that is security bolted into a tube type object?
Old Sep 21, 2004 | 03:38 PM
rmarsh3309's Avatar
Here's my experience with MAF replacement. My real-world experience was totally different than most of what I read on these forums. It makes me think my 00 GLE must be "special" somehow.
http://forums.maxima.org/showpost.ph...1&postcount=19
An additional note: the electrical connector will not release unless you press down with a small straight-blade screwdriver at the location marked with a small arrow. When re-connecting, press it down again in the same spot to "re-latch".
Best of luck.
Old Sep 21, 2004 | 03:48 PM
jessemcd's Avatar
I did mine last weekend and it was the best mod ive done for my car! I know its not a mod but it sure feels like it. My car has all of its juice back and i love it once again!
Old Sep 26, 2004 | 04:19 PM
fatboyp's Avatar
Just the sensor....
ABDomega, I believe I'm getting just the sensor.....the part number is 226802Y001. Ordered it from Jerry Rome Nissan last week. I'm itching to get the new one put in as I'm reluctant to drive my car with the SES light on.
Old Sep 26, 2004 | 06:08 PM
Progress's Avatar
It's business time.
If you are getting the sensor alone, (as opposed to me, I got the whole tube construction, and I had taken apart my airbox several times so that was easy to replace), then you have to get a special wrench to pull out the security bolts holding the sensor in the tube. Then you will need to pry, pull, wiggle and twist the sensor out of it's place (a rubber gasket/o-ring is holding it in). Then put the new one in in the same manner, twist and push. If you still have an SES light then you should first go to Autozone and get the codes pulled free of charge. I think that if you have a new MAF then you shouldn't have the light, because the blown one is most likely making an O2 sensor read wrong making the engine run lean (that was my problem, although I had no SES light).
Try just unplugging it over night and if the light doesn't go away and you are still pulling codes then go to the dealer as a last resort.
GL
Old Sep 26, 2004 | 07:00 PM
Andrew's Avatar
dude,
you're getting the entire assembly..sensor and tube. I have the same part number in front of me and the part. Also ordered it from the same place!
Cheers.
Andy
Old Sep 7, 2009 | 09:34 PM
sonnys6's Avatar
I just installed a new Nissan MAF in my 2001 Maxima. I realized after installing it that I hadn't checked if the new one had an o-ring on the air filter (screened) side. Does anyone who has done this previously remember if they had to move the o-ring over to the new one, or if the new one came with it already installed?
Thanks,
Sonny
Old Sep 7, 2009 | 11:24 PM
kc10fish's Avatar
so easy a caveman can do it!
Old Sep 8, 2009 | 12:20 AM
jasonmax's Avatar
see my sig.
Old Sep 8, 2009 | 12:39 AM
BronxSleeperMax187's Avatar
came with it installed
Old Sep 8, 2009 | 09:10 AM
Progress's Avatar
It's business time.
5 year-old thread.
Old Sep 8, 2009 | 09:31 AM
Jmahad01's Avatar
Originally Posted by Progress
5 year-old thread.
Atleast he searched lol.
kjlouis
Nov 24, 2018 06:09 AM
vingodine
45
May 21, 2016 12:46 PM
vanebecker
Aug 19, 2015 09:45 AM
