Unresponsive Gas Pedal
Old Sep 23, 2004 | 06:21 AM
digimax's Avatar
The other day my SES light came on. I went to work and everything seemed fine. However at lunch, I started the car - shifted it into reverse and steped on the gas and nothing happened. I rolled in the street and shifted into D, pushed down the gas and still nothing. My Max just idled forward. I tried a few more times to "rev" my engine and nothing. I finally parked the car, let it sit for about 10 minutes and it seemed fine again. The SES light is still on, but can anyone give me some suggestions on what could be wrong or has anyone had the same problem on a 03 automatic Max?
Thanx
Old Sep 23, 2004 | 07:17 AM
Daily Driver2k2's Avatar
Sounds like your TPS (throttle postioning sensor) malfunctioned, or your MAF sensor is malfunctioning. You should take it to Autozone, they can read error codes that kicked off your SES light and isolate the problem.
Old Sep 23, 2004 | 07:40 AM
digimax's Avatar
Thanks for the imput.
My car is still under warranty and is at the dealership right now, so I just wanted to know what I could expect from them. I guessing that should be covered.......
Old Sep 23, 2004 | 08:44 AM
fornimage's Avatar
Please keep us informed at to what the problem was...I'm very curious. Thanks.
Old Sep 23, 2004 | 08:54 AM
Puppetmaster's Avatar
Thanx
Buddy of mine in Michigan had the same thing happen with his 02 Max... said there was a recall done for that? I have no idea... but I'll find out from him what exactly went wrong....
Old Sep 23, 2004 | 09:48 AM
SR20DEN's Avatar
VQ Wizard
This is most likely a dead TPS. The ECU can't see the pedal position so it doesn't know to adjust the throttle accordingly.
Old Sep 23, 2004 | 10:23 AM
fornimage's Avatar
Correct me if I'm wrong but doesn't that mean the whole throttle body needs to be replaced if it was the TPS?
Old Sep 23, 2004 | 01:04 PM
digimax's Avatar
For those that were interested in what the dealer found out, here it is:
They had to order me a new Electric Throttle Control Actuator, I guess the one I had went bad and this should fix it.........
I get the car back tomorrow, so I'll keep my fingers crossed.
Old Sep 23, 2004 | 01:14 PM
fornimage's Avatar
Digi,
How many miles do you have on your 2002? I have ~44,000 and mine went but I had a diff. condition. My car would idle around 1000 rpm compared to a normal idle of 700-650 rpm but it would drive fine. I am waiting for a used one to come in to fix the problem.
Old Sep 23, 2004 | 01:22 PM
digimax's Avatar
My 2003 has about 31,000 on it.......so luckily it is still under warranty. How did you know it went? Your SES light came on?
Old Sep 23, 2004 | 01:50 PM
fornimage's Avatar
Yeah, the SES light came on and 5 codes were pulled that all pointed in the direction of the TPS or the Electronic Thorttle Actuator being bad. I thought I was the only one that had a bad throttle body this early. I still don't like how Nissan switched over to electronic throttle bodies. To get a brand new one it'll cost ~$750 from the dealer! A used one will cost half of that so you are lucky you are still under the factory warranty.
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
