Starting problem??????????????
Old Apr 10, 2001 | 08:04 AM
RMcoolX's Avatar
I've noticed that my Maxima cranks very slow sometimes. When I turn over the ignition, 50% of the time it cranks as quick as any other car I've owned, but the other 50% of the time I have to hold the key for 2 to 3 seconds.
Is this normal or is it something I'm doing wrong? I do not give it gas while cranking, nor do I press the accelerator before cranking. I just simply turn the key.
Before I take it back to the dealer, I would like to know from you guys what may be going on.
Thanks.
Old Apr 10, 2001 | 08:32 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
I have this problem, but it's only on and off. Someone posted about within the past four days or so. See if you can dig it up (it was a TSB).
Old Apr 10, 2001 | 09:01 AM
UMD_MaxSE's Avatar
Got Bent?
The TSB for this happening had to do with the immobilizer key not being recognized quickly enough, I think....
Old Apr 10, 2001 | 09:07 AM
psing23's Avatar
i have a question that has to deal with this a little... what happends when your car is already started and you forgot and u turn to start it again? you hear grinding... is this bad for the car if u do it once for a few seconds? I just did it this weekend... ive done it before on other cars but i just wanted to know what is actually making the grinding noises and in theory if lets say you would hold it like that for an hour what would happen?
Old Apr 10, 2001 | 09:09 AM
UMD_MaxSE's Avatar
Got Bent?
The grinding would probably be your starter.....and it is bad to let it grind...very bad....you would need a new starter if you did it for a long time. A crank or two, I wouldn't worry about tho...
Old Apr 10, 2001 | 09:13 AM
psing23's Avatar
ok thanx!
i knew it was bad i just wanted to see how bad
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
cruce91
Sep 20, 2015 10:23 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
