grounding point for a manual tranny on a 2k2?
probably so he can ground the tranny.......
I intended to run a wire to the tranny when I made my hyperground, but haven't gotten around to getting the bolt that I need for the threaded hole in the tranny....
ummm...yeah for the hyperground kit, i was gooing to run a wire trhough the tranny grounding point, but since i dont know what it is i ran it through the body...ill change it once i find the point
heh thx bro it was actually your writeup that i followed for my hypergrounding, one hting though i am assuming you are and auto because whatever your grounded on this pic i do not have.....
maybe i got a weird maxima thats missing parts..
There should be a smalllll wire that connects to the tranny as a ground already, it sits around the ABS modulator area. It has a female connector on the wire, and male spade connector on the tranny case bolt. The ground Wildmanal has should be on a manual 3.5L also, as without that ground the starter will not crank the engine over. Its one of the MAIN grounds in the engine bay, my 5spd 3.0L has it. I'm doing my own grounding kit also this week, right after I do my clutch, SMC shifter w/ES bushing, install the big brakes, and flush every fluid in the car out with new Redline/Mobil/Motul stuff
Big week for the Maxima this coming week.
Mar 12, 2020 12:06 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
