VIAS stuff
Old Nov 8, 2005 | 10:03 AM
  #201
dennisuello's Avatar
took mine apart last night, to make sure it was not broken. and it looks as good as new. that's on a Max with 100k miles. I put in some JBWeld while I was in there, but it was tight with no signs of failure. all this work and two stripped screws for nothing.
Old Mar 18, 2006 | 09:30 AM
  #202
ODB's Avatar
ODB
affect on automatics
So let's say I have a 2K automatic and don't find myself over 5K rpms very often. This fix has no impact below 5K right? Thanks.
Old Mar 18, 2006 | 03:01 PM
  #203
Mike T's Avatar
ignotum per ignotius
Correct, excluding the small possibility that the VIAS has failed, and the valve assembly is stuck in the "high-rpm" position, or in a part-way position. This would significantly reduce power in the sub 5k range.
However its unlikely.
Old Apr 4, 2006 | 09:08 AM
  #204
nicks79's Avatar
Originally Posted by spirilis
That's good. I'm going to dremel out the old crap from my old VIAS box, see about lining it up perfectly, provide some measurements (w/ protractor and/or ruler so people can get it perfect) and try using Original JB Weld, let it cure for 2 days, swap it in and drive it for a month and see how it performs over time. It's nice having a spare manifold w/ a perfect VIAS box that's not broken
Hey, I was wondering if you got the chance to measure the exact position of the cup on the shaft? Mine is so loose that I can't tell exact position and I think if I twist it few more degrees to eaither side, while JB'ing it, it wouldn't be good.
Old Apr 28, 2006 | 08:31 AM
  #205
nicks79's Avatar
Anyone know the angle of the cup in the right position.????
Old Apr 30, 2006 | 06:44 AM
  #206
mhadford's Avatar
All I can suggest is to look at the pictures I took, and also look at the orientation of the power rod (if possible)
Old Feb 10, 2008 | 02:56 PM
  #207
Armon's Avatar
Proper cup position
I'm resurrecting this thread because (1) it is immensely helpful, and (2) it's somewhat obscure relative to how important it can be. I just happened to stumble across it while I was looking for something else. Of course you could find it if you searched, but it seems like something that should be displayed for all to learn about. Why isn't this sticky'd yet?
Short version of the rest of this thread, for the newbs like me out there: On the 3.0 5th gens, there is a weak point in your variable intake. If it is broken, you lose about 30hp above 5000 rpms. You can fix it with JB weld. Check the rest of this thread and mhadford's write up.
My car probably hasn't seen that many redline runs in it's life, therefore the "cup" pictured below is still attached (but it is loose). On some, the cup is completely unattached.
Because the cup is still attached, THIS IS THE PROPER CUP POSITION.
Old Feb 10, 2008 | 05:02 PM
  #208
choiiiiiiiiiii's Avatar
not going to condone this because of the usefulness this will serve for future newbies.
Old Feb 11, 2008 | 12:26 AM
  #209
AceofSpds's Avatar
wat
Thankyou SO much for posting that, ive spent so many hours looking for that in the past month or so ive been playing with my VIAS.
BTW for those that fixed theirs w/ JB weld you might wanna check it, my cup is completley rounded out now
Old Feb 11, 2008 | 04:28 AM
  #210
Product_Of_Korea's Avatar
http://www.vqpower.com/v2/readarticle.php?article_id=21
http://www.cardomain.com/ride/763858/5
Old Feb 11, 2008 | 07:31 AM
  #211
Armon's Avatar
What do you mean by rounded out?
Old Feb 11, 2008 | 12:34 PM
  #212
chadsexington's Avatar
yea what Do u mean by roudned out? it was a pain in the @$$ taking that thing off
Old Feb 11, 2008 | 03:03 PM
  #213
AceofSpds's Avatar
wat
the lower portion of my cup that used to attach to the actuator rod
Old Feb 11, 2008 | 03:11 PM
  #214
i better pull mine apart n see if its still attached
how reliable is this JB weld glue?
Old Feb 11, 2008 | 03:48 PM
  #215
Armon's Avatar
So the cup was freely rotating around the rod again? Did the JB weld crack or what?
Some people in this thread found that the JB Quik was not strong enough, and ended up cracking. The good old fashion JB weld is stronger, but takes 24 hours to cure.
Old Feb 12, 2008 | 03:57 PM
  #216
Mike T's Avatar
I did this repair with the regular JB Weld at around 90,000 miles. Currently at 217,000 miles and it is still holding (hundreds of times reving past the vias activation point). Just make sure to use the regular JB Weld, use just a dab, orient the cup properly, and let it set for 24 hours. It should outlast the rest of the car.
Old Jan 3, 2009 | 01:49 PM
  #217
gpmax's Avatar
I am subscribing because it took me forever to find this!
Old Mar 29, 2009 | 06:42 PM
  #218
Red_Liner740's Avatar
Thanks guys, i suspected something was wrong when it would take a wihle to rev up to redline....great bottom end but the top was lacking, found out this VIAS problem and took it apart today...sure enough the cup was totally detached. did the JB weld, put it back together and i would rev the car past 5K and see the actuator pull it back but it wasnt springing back to original position
too much pressure on the cup was causing too much friction....took it apart and ground down the rod, assembled it back and now she works like a charm, much more liniar power all the way to redline....no more dying off, i find myself bouncing off the limiter now cuz i cant catch it fast enough in first....
great help guys!!
Old May 1, 2010 | 12:15 PM
  #219
kingrukus's Avatar
no more maxima...
can someone post the proper cut orientation? the pic above isn't working. my cup was loose, but still attached - though the groove was worn enough that the cup was definitely not oriented perfectly. The rod's notch seemed to be facing directly forwards (i.e. to the front of the car), so I am wondering if that was the correct position?
Old May 30, 2010 | 04:01 PM
  #220
Rods03Max619's Avatar
Old May 31, 2010 | 12:54 AM
  #221
a33_ridah's Avatar
will be doing this tomorrow hopefully on my 140k driven 00 gxe
Old Jul 22, 2010 | 08:08 AM
  #222
pyroz's Avatar
my 2000 SE at 104k miles seems to be losing power when going uphill. Could this be the problem?
Old Jul 27, 2010 | 03:52 PM
  #223
mhadford's Avatar
Could be, if you are feeling the power drop off around 5,000 rpm. It's worth a look.
Old Jun 27, 2011 | 09:56 PM
  #224
secured2k's Avatar
I recently acquired a 2000 Maxima. Since I don't know how well the previous owner maintained the engine, I've been looking at ways to fix her up. I decided to look at the VIAS (or VAIS?) and found my cup was still attached but loose. I could rotate it between say 3 and 4 o'clock. I tried searching the forums and google but cannot find any working pictures of the proper/standard positioning. I even tried a dealership service center and they couldn't find the part in their exploded views.
Does anyone have a working stock picture of the cup orientation?
Does it really matter if it's off by 5-10 degrees? The part that the cup rotates seems to be smaller than the indentation so there would be some play in the movement in the intake manifold.
I set mine to about "3:30". Would I have been better off setting it at a full 4:00 or 3:00 position?
From another thread...
http://forums.maxima.org/all-motor/3...i-parts-3.html
Photo 2: As I slowly turn it towards the firewall ( if it was installed in the car) notice position change.
Photo 3: Fully turned
Old Jul 2, 2011 | 03:06 PM
  #225
BobPezz's Avatar
2001 VIAS Actuator Vacuum Hoses
This is going to sound REALLY stupid. I did the VIAS actuator repair today. Labeled all the vacuum hoses except for the 1 that goes on the T connector with 2 hoses at the front of the unit above the electrical connectors. There's a loose hose coming from the right side top front of the solenoid unit that I think might have come off the T connector. The engine is a 2001 VQ30DE-K, Need Advice PLEASE!
Old Jul 3, 2011 | 08:50 AM
  #226
mhadford's Avatar
I blew up my old motor and just replaced it with a rebuilt. I found that my vias cup was royally damaged. The opening for the metal rod had become a jagged round hole, despite the JB weld. Cleaned it up and tried to MIG weld the cup to the rod, but it didn't work - the cup metal is too thin. Going to weld a steel washer to the cup, then to the rod. I'll let you know how it goes....
Old Jul 3, 2011 | 08:57 AM
  #227
BobPezz's Avatar
VIAS Fix
First off, thanks to the MAXIMA.ORG members for providing this valuable info. I just completed the VQ30DE-K "JB Weld VIAS Fix" on my 2001 SE 4AT. The results were satisfying to say the least. By "Butt Dyno" it seems to have improved torque (pulling power) overall and the engine pulls smoothly from standstill to a bit less than (an indicated) 125MPH at 6000RPM with "OD Off". There looks like a slight hesitation on the Tach at roughly 4500RPM, but the engine keeps building RPM's with no loss of high speed acceleration. The low end on takeoff now has authority (important with an AT). I can spin my (225-50VR-17) tires from a dead stop with about 2/3 throttle and "Bark" them on a WOT 1<=>2 upshift/downshift. My VIAS wasn't totally broken, but had roughly 15-20deg. play in the cup. From the noticeable difference in drive-ability, the power valve obviously wasn't opening/closing totally.
Anyone with a VQ30DE-K and/or 00VI manifold needs to check out this fix!
BTW; My panic on the VIAS Actuator vacuum lines was premature, once everything was back on they practically fell into place.
Old Jul 14, 2011 | 06:04 PM
  #228
BobPezz's Avatar
VIAS Fix
FYI; I noticed a decent improvement in mileage since the "VIAS Fix". Got roughly 80 more miles on a tank of fuel (E10) since the repair. Not earth-shattering, but an improvement none the less.
Old Jul 15, 2011 | 02:27 PM
  #229
NmexMAX's Avatar
dot dot dot ...
Yet another satisfied customer.
Old Jul 16, 2011 | 03:43 PM
  #230
BobPezz's Avatar
ABSOLUTELY!!! Thanx again to the .org for the info.
Old Jul 17, 2011 | 02:38 PM
  #231
NmexMAX's Avatar
dot dot dot ...
SSIM + supporting mods + 7100 > VIAS
Old Sep 28, 2011 | 05:42 PM
  #232
T_Behr904's Avatar
Bump for such an informative thread! I will be doing my JB Weld fix on my car here in the near future.
Old Sep 30, 2011 | 07:54 PM
  #233
Super Shadow's Avatar
This is a very infomative thread. i didn't however find the orientation that the power valve should be in when JBing the cup back to the rod. i found out mine is totally seperated from the actuation rod and have no idea where the power valve should be setup. Oh and we can't just order the vias actuator assembly from the dealer seperatly? we have to buy the whole manifold?
Old Sep 30, 2011 | 08:09 PM
  #234
L36's Avatar
L36
Il be looking at my VIAS as well. I have a feeling its broken as i do get that "bog" feeling when i hit 5K+ RPMs when i merge on the highway.
  #235
BobPezz's Avatar
I think there's a good orientation photo in post #186. The rod in the intake should if (I remember correctly) have the key pointing roughly toward the front of the car. As far as the other questions I don't know for sure.
Old Oct 6, 2011 | 09:14 PM
  #236
L36's Avatar
L36
Does anyone have any pictures of the proper cup position? I'm pretty sure my VIAS needs to be fixed. Thanks.
Old Oct 7, 2011 | 04:02 AM
  #237
BobPezz's Avatar
I think there's a good orientation photo in post #186. The rod in the intake should if (I remember correctly) have the key pointing roughly toward the front of the car. SEE POST #235
Old Oct 9, 2011 | 03:01 PM
  #238
L36's Avatar
L36
I did not get to fixing my VIAS on Friday, but will on Tuesday. Question is, should i put back the spring while the JB is still tacky and sink it into the JB, or wait til its dry to put the spring back?
Some say if i go for option 2, the spring wont have enough clearance...
Thanks.
Old Oct 10, 2011 | 03:28 PM
  #239
BobPezz's Avatar
Thanks.
I didn't have ANY problem with the spring. It all depends on how much JB Weld you put in the bottom of the cup. If you follow the instructions and use ONLY enough to slightly cover the rod end you should be fine. I took the extra step of coil binding the spring in a vise for the entire time, including 24hr JB Weld cure to shorten it up nicely.
Old Oct 11, 2011 | 08:08 AM
  #240
L36's Avatar
L36
So one of the screws is a PITA, removed all three with little effort but the last one all the way on the bottom is being a pain and Ive already slightly stripped it enough for my screwdriver to skip. I might be able to get it out with a thicker screwdriver. Going to hold off from taking it off and get a thicker one.
Edit:
Got a thicker screwdriver, well i applied insane force and the screw wont budge, stripped it further... Any other suggestions? Pliers will not really fit in there.
Getting slightly upset about no 30 ponies for me.
Further story, came to sears this mourning to pick up the said thicker screwdriver, get it, attempt to start the car. Starter cranks and just loses it. Try again, cranks very poorly. Try last time, smell something melting like.
Anyway, walked like 3 miles home, grabbed the other car, got the starter from autozone, picked up my mom to take my other car back home when i came back to sears. Replaced there in the parking lot. Car starts like champ now.
Pretty cool day.
