2001 SE 20th Anniversary Edition VS. 2000 Infiniti I30
Old Sep 28, 2004 | 04:16 PM
japmaxSE's Avatar
Go Get a Life!
I'm in the middle of puting one of these engines in my 4thgen I want to know what exactly makes the 227HP 2001 20TH Anniversary maxima have 5 more horses than the base 222HP 2000 and 2001 maxima's? And I figure that the 2001 Anniversary model is the same engine offered in the 2000 Infiniti I30. Was there any change from the 2000 I30 engine to the 2001 anniversary engine thats a whole year and same 227HP? Last but not least I know I will have to get the wiring harness and ECU to do this If I'm wrong please let me know.
Old Sep 28, 2004 | 06:15 PM
A33 VQ30DEK's Avatar
theres really no difference. That extra 5 hp comes from the "special exhuast they have". The Varible Exhaust
Old Sep 28, 2004 | 06:42 PM
Loe max's Avatar
The B-pipe and the ECU part# from the AE matches up with an I30 and different from other Maxima's. Everything else is shared between the Maxima and I30.
Old Sep 28, 2004 | 06:57 PM
jessemcd's Avatar
Let us know how awesome your car is after you put in the new engine. Time slip would be cool also!
Old Sep 28, 2004 | 07:23 PM
2k1AEMaxRider's Avatar
And i thought is was the little decal on the back that made mine faster, lol.
Old Sep 28, 2004 | 08:24 PM
SoonerFan's Avatar
Cletus
all 00/01 have variable exhaust. its something diffirent that gives them the 5 extra hp.
im going with.......the engine cover or headlights
Old Sep 29, 2004 | 01:01 PM
Loe max's Avatar
Its the shifter and pedals
Old Sep 29, 2004 | 03:41 PM
SoonerFan's Avatar
Cletus
good call!! the pedals make it easier to floor it and the shifter **** makes shifting quicker. so i should have 2 1/2 extra hp since i have just the pedals
Old Oct 1, 2004 | 06:42 AM
Anuj's Avatar
you guys are all wrong
think of the super aerodynamic bodykit..that is why the car is so fast...it belongs on the f1 circuit
Old Oct 1, 2004 | 07:47 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
All the hidden HP is in the ECU, they are different, the rear muffler has curved down tips but its basically the same thing as the 2000 Maxima muffler other than that. You will need the ignition switch, ECU, harness to make it all work. If your 4th gen does not have immobilizer than you will need the ignition switch portion to start the car up. You could use the stock 4th gen wire harness and ECU but the VIAS wouldn't work, and the car would run rich as 00-up use larger injectors- same as the 350Z as a matter a fact.
Old Oct 1, 2004 | 08:18 AM
spirilis's Avatar
BTW, with that engine, I recommend you pull off the VIAS control box and do the JB Weld fix we're talking about in this thread-
http://forums.maxima.org/showthread.php?t=341077
It can make or break the performance. The thing could even perform similar to a 4th gen's engine without that mechanism working properly.
This is in relation to the VIAS, BTW. The VIAS is the premier horsepower/torque-increasing feature of the 2k-2k1 VQ30DE-K engine. I suggest you wire it up using something similar to what the MEVI guys use, e.g. Summit RPM switch. You won't need a vacuum tank though, it has one built into the manifold (part of that VIAS control box, although part of the tank is inside the manifold with a hole exposed to the VIAS control box).
Old Oct 1, 2004 | 10:52 AM
GreenSeMax's Avatar
one of the differences is the stock intake setup, the oil separator is different, and there is no downpipe before the ram air setup where the temp sensor is. the intake is the same as the I30, with no baffle below the filter, the ecu is different, and the b-pipe, other than that, i'm not sure
Domf3
Sep 22, 2015 03:05 PM
ballerchris510
Sep 11, 2015 05:29 PM
