2k2 Dyno: Cattman's Headers vs Y-pipe
#43
Originally Posted by bgates1654
Fezzik you didnt happen to get your A/F ratio analyzed did you? Go for the SAFC-II next I would love to see the power you would be putting out with some tuning. Then get the L-spec TS ECU I am sure you will be in the 250whp range then.
#44
I do not think anyone else dynoed the same day. I got out of school early and was able to get there before anyone had a chance to get there. THere was an evo on there but he had dynoed it a few days back. It was producing 490whp. LOL wish i could do that right now. Ok, well i wasnt really thinking of doing the TS ECU cause it was a lot of money and some people were not getting gains. But now that I have headers which i originally hadnt plan to buy, so i may. If I get the TS ecu i do not know if i need the SAFC. I also have a spare 2k2 ecu that I would use to dupe my origial ecu onto. I truelly havent ever messed with this stuff. But I'd like to start workin with a SAFC II maybe. SO we shall see.... when i get more money. Uncle Sam is gonna want his money back soon.
#45
Check this out. TS ECU Dyno Read the entire thread though. Read about the L-Spec TS ECU HERE
L-spec TS ECU is $345+shipping and if you get it you will need SAFC-II for tuning the A/F and timing. You can get the SAFC off ebay for 250+shipping maybe less.
#47
Still Here... IM me for more..
i made huge gains with my cattman catback and headers on my 2K... of course I WAS supercharged back then... i can still feel a difference with the catback and headers on my 2K2 though...
#51
Originally Posted by IceY2K1
SAFC only does fuel....you NEED an eManage for fuel and timing.
has anyone gotten the emanage to control the timing correctly yet? i thought dixit wasn't able to get it working...
#52
He got it working, but did have a pending code.
Other 4th geners have and many VQ35 350Zs have the timing working.
If you use the diodes and have the latest firmware version, it doesn't fry coils.
#54
MJG, any bolt on part is just freeing up horsepower (unless you consider boost and/or juice a bolt on).
#55
01 Cali spec vehicles do not have EGR ports on the exhaust manifolds. You need a Air injection valve plug for a 94 Sentra SE-R. It is the same size as the EGR pipe bung, 91-93 SE-Rs had air injection valve which connected to the secondaries of the stock exhaust manifold, in 94 they removed the AIV from the SR20 engine and put a plug in the exhaust manifold secondaries- or the downpipe as some would call it.
#57
I have done a VIAS on my car and looked down at the manifold- nothing there, I also did my PR motor mounts and looked at the manifold to make sure, and my car has no EGR fitting on the rear bank- one manifold.
#58
#59
My car has a production date of April 01, which would make it a very late 01 cause 02s where already built in June. When I ordered up my VIAS I needed the VIN cause there are some production changes. As a matter a fact I get asked for the VIN alot when I go in for odd parts for my car- like bushings, gaskets etc. I know for a fact my front exhaust manifold I had on my car is the same one as the one used on a 3.5L cause the stampings on it. The front close coupled cat is the same as my friends 02 Maxima's. We compared them when I did headers on our cars.
#60
I just want to say thanks for the great comparison and it's good to see the headers made such great gains. I wish someone would do this comparo with a 4th gen. All us 4th geners have to go off of is track results and no one has shown any significant improvement in ET or MPH over just a standard y-pipe. Since the 4th gen Y-pipe removes the precats, the gains are far better with these y-pipes and it's probably why we aren't seeing measurable gains at the track.
#61
Ok here is the info about each dyno
Pre-headers: Barometric pressure 29.52 in.Hg; Vapor Pressure 0.16in.Hg; Intake temp 90.8F
Headers Installed: Barometric Pres 29.46.inHg. Vapor Pressure 0.12in.Hg; Intake temp 86.2F
#63
Thanks to Dave for this, although my neck is still sore from all the wiring I had to do! Dave's car showed GREAT gains immediately after the install. We were playing around on the highway and I was VERY impressed with how the car is running w/ the headers. Thanks again Dave. You need to borrow my slicks on your next trip to the track for sure.
#66
Hmmm, I can't fully agree with what you've said. Gains of a little under or over 20hp are typical on 95-99 VQ30DEs and a few hp better on the 225hp 00-01 VQs (compared with a stock y-pipe). There are no y-pipes that make that power and any tests I've seen that suggest otherwise are clearly bogus (based on wierdly anaemic baseline runs, not strong y-pipe runs).
As I recall, Ceasar's Chariot added the headers during the summer and held the same track times at 90+ degrees that he was running w/o the headers when it was much cooler. Hardly a definitive test, but the headers had to add significantly more power than the cheap y-pipe they replaced for this to occur - nothing ambiguous about it, that's basic physics.
Hopefully we can get a good dyno from a VQ30DE owner (preferably showing the difference between a performance y-pipe and the headers) when the new headers come in later this week - we offer a $50 rebate for dyno fees if the customer contacts us ahead of time and has the test done and recorded the way I need it to be.
Agreed that the headers do better on the VQ35DE, but I suspect that has more to do with replacing stock exhaust manifolds than the pre-cats - precats don't typically rob that much power but every other stock exhaust component on the 02+ Maximas seems to.
Brian C Catts
Cattman Performance
#69
Originally Posted by E55AMG2
I had no fitment issues with my HS headers, and I can name a few more who didnt.
i forget if there are any HS dynos floating around...anoyone? i'd expect them to be slightly less if they didnt have intake, but if the power gains are very close then i can't justify the extra 275 bucks...that's like an intake right there!
TallTom
50
07-08-2022 09:54 AM
KabirUTA13
19
10-17-2015 02:15 AM
