Anyone replaced Mass Air Flow sensor?
Has anyone replaced Mass Air flow sensor?
Dealer wanted $375 to replace $100 part in one hour. Wanna do it myself.
Has anyone done it? If so, is there anything particular to it?
And olso , how do I shut off Check Engine light after I changed Air sensor?
Nick
Nick
i have an '02 as well. you will find a plastic piece that's screwed into the piping (also has a plug into it) that leads from the stock air box. it's very easy to find. I had to use the a standard (flathead) screwdriver to CAREFULLY pry it out. you'll pull out the housing (which is a plastic piece about 3-4 inches long), and the sensor is a small metal wire (looks almost like a paper clip) with a small resistor on it.
another comment on the check engine light... if you go to the FAQs portion of this site there is a reset procedure that does not require unplugging the battery.
It involves timing pedal pushes... took me maybe 5 tries until I got it but sure enough the light was off and i didn't lose my radio station presets. Just look for ECU Reset Procedure or something like that.
Nick
Nick
Yes, you can change it yourself. Don't replace the entire unit you get from the dealer. Just unscrew the sensor and take that part out and install that into the MAF housing. Removing the entire housing will take a long time.
Also since you have a 2K you may have to take it to the dealer after to reprogram the ECU for the new updated MAF. The general concensus on this is that it needs to be done. There have been many threads on this.
So I changed it
Took me about an hour, but i replaced whole unit, with the housing. Started the car and it runs like a baby, just like a new one. Got the power back now. Light is on, but will have to reset it, so if anyone knows how, please inform, otherwise will search FAQ for an answer.
Price for unit was $106, here in Boston area.
I belive the MAF information should be a STICKY... this topic comes up every week now. 00-01 cars can't just reset the ECU, there is a updated MAF ECU program that needs to be uploaded into the ECU. If you want the best MPG and your car to really run right you need to get the ECU update for the MAF. I noticed I picked up almost 4MPG from doing just that and car felt alot more powerfull at low end.
Can I get my ecu reprogrammed after I install the part? I just bought a new MAF today and the guy said that they had to reset the ecu, but I figured I could do it myself. But if something needs to be added then I guess they have to do that, right? And I paid $123 for mine her in Maryland.
if you want to do it yourself for under $100 lookey here
http://forums.maxima.org/showthread.php?t=302224
just follow the thread and you'll see a link for jerome nissan and the part#
i did it...it was easy!!!
Unless you have a cracked housing causing an air leak all you need is the sensor.
Call DAVEB and order it from him. It's been a while since I've seen a price on 1 from him but for a 2k it sould only be like 80 bucks or less.
This is a 2min job.
disconnect the wiring harness from the old MAF. 2 Torx drive screws hold it to the housing, remove'em. Put the new MAF in tighten the screws and reconnect the harness and your done.
This is a 2min job.
Okay, putting it on is no problem. Especially since I was familiar with the parts from assembling the Frankencar Intake a while back. But I was told that the car needs to be reprogrammed and updated. Plus I can't get that damned SES light off my dashboard. How do I get rid of that?
As far as the SES, that will be taken care of during the reflash. There are other ways to turn the light off but since you need a reflash it's better to have it on when you go to the dealer.
bc992164
Aug 26, 2015 12:19 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
