Interior Lighting Question for 2002
Old Oct 11, 2004 | 05:47 PM
MrMaximaGLE's Avatar
My max seems very dark inside, even at the highest setting the dash is dark to me, I have a GLE with black gauges so maybe that's it.
Those with heated seats - do the 2 little switches light up when your lights are on? Not the orange light when the heater is on, but the actual switch itself?
On your doors, do the lock/unlock buttons light up?
On the auto climate control , do the "auto" , "econ", "off", etc. buttons light up?
Thanks,
Keith
PS - This 02 Max sure has a ton of BS problems, my father-in-law had the 3 Maxs before the 5th gen and he loved them, he's shocked at how the quality dropped
Old Oct 12, 2004 | 09:15 AM
Does anyone know if these various switches light up???
Thanks,
Keith
Old Oct 12, 2004 | 09:38 AM
Techman's Avatar
I have the same problem. Even if the brightness **** is at maximum, the cluster is very dark. My previous Maxima (1991) was much brighter.
I bought the car used. Maybe the previous howner changed the bulbs for low wattage one.
The heated seat switch are not lighting in my car. The electrical schematic show only power indicator, no illumination lighting.
All the climate control buttons light up. For the lock/unlock I dont now I will check tonight.
Old Oct 12, 2004 | 10:18 AM
Thanks for the info.
Keith
Old Oct 13, 2004 | 06:17 AM
Is there anyway to brighten up the dash lights???
Old Oct 13, 2004 | 09:04 AM
Techman's Avatar
The lock/unlock button is also lighted.
The only way to change brightness level is to change the bulbs in the cluster. I think you have to remove the cluster to check the type off bulb used. Not an easy task.
I hope this will help. If I find an easy way to brighten up the display I will post it.
Old Oct 13, 2004 | 01:18 PM
Can you put an Infiniti I35 cluster in our car? Those are really bright.
Keith
Old Oct 13, 2004 | 05:29 PM
MaximaDudes's Avatar
yea, my heated seat lights dont either, they're obvoiusly not supposed to.. but does anyone think that it is possible to make them light up?
Old Oct 14, 2004 | 11:23 AM
Techman's Avatar
The lights of the two heated seat switches were burned out. I opened the casing of the switch and replace the bulb with Radio Shack one. Use the mini 12volts.
I closed de casing, replug the switch and it's working like new.
Old Oct 15, 2004 | 03:37 AM
tecman are you talking about the orange indicator or the actual switch lighting itself?
Keith
Old Oct 15, 2004 | 09:11 AM
Techman's Avatar
Yes, in my 2002, there is only one bulb in the switch to give on/off indication. No illumination.
doobadoo
Aug 15, 2015 06:43 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
fastcarny
Aug 12, 2015 03:50 PM
yat70458
Aug 3, 2015 01:16 PM
