Cone Filter Install
Old Oct 12, 2004 | 05:34 PM
DUKEE's Avatar
Cone Filter Install
I know this is probably the easiest install there is.. but i just had some questions about it. I removed the existing air box and replaced with a Cone Filter which i attached with that steel adapter that connects from the cone filter to the tube...now correct me if im wrong is the MAF sensor located behind the mesh screen inside the tube? is there anything i should watch out for, i dont want to damage the MAF sensor? Lastly the air temp sensor that was on the stock airbox it is now left hanging.. i have it tied with fishing line beside the cone filter..is that where it should be? Thanks in advance for these lame questions ;D
Old Oct 12, 2004 | 09:17 PM
scopium
you are correct
Old Oct 12, 2004 | 09:46 PM
jklx86's Avatar
i didn't know u can just put a cone filter on like that...i thought u needed the midpipe to fit a cone filter??
Old Oct 12, 2004 | 09:58 PM
Puppetmaster's Avatar
A midpipe just smooths out the airflow... you can do w/o it provided you have the adaptor to connect the cone to the MAF....
MaxLife17
Jun 27, 2019 01:37 PM
The Wizard
24
Oct 1, 2015 08:47 PM
aminus21
Sep 12, 2015 04:53 PM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
