Who has the trunk mod?
Old Oct 13, 2004 | 08:47 PM
NJ Devils Fan's Avatar
I was looking at someone's car domain site a few days ago of a white 5.5 gen max that, when you opened the trunk, it stayed level, did not "open," it basically "lifted" up. Who's max is that?
Old Oct 14, 2004 | 05:57 AM
TrexMax001's Avatar
Here is my buddy Tekniq's car,
http://www.cardomain.com/memberpage/598084/4
I'm hoping we get to do mine sometime soon.
Trex
Old Oct 14, 2004 | 06:22 AM
xTeCaOx's Avatar
i have this mod too..... VERY easy to do and cost about $5.00 at the most from home depot.......i made it so i can leave it stock or do the flip flop effect when ever i feel like it, ill try an post some pics soon for all to see
Old Oct 14, 2004 | 06:52 AM
wngan9447's Avatar
Chicken Feet Croo!
Can we have a write-up?
Old Oct 14, 2004 | 07:23 AM
I30swimmer's Avatar
yeah write up please buddy
Old Oct 14, 2004 | 08:13 AM
Manaz101's Avatar
Old Oct 14, 2004 | 08:38 AM
PoLo's Avatar
2-Wheelin it...
Originally Posted by Manaz101
door hinge betweent he bars and the trunk lid. let's you keep it level. that's all.
Old Oct 14, 2004 | 08:59 AM
custommaximaSE's Avatar
Its called (Flip Flop Suicide Trunk ).
You can buy this Mod Instructions from Ebay ,its only $3.99.And you can still open your trun the normal way after you do this mod to your trunk lid.
http://cgi.ebay.com/ebaymotors/ws/eB...928194052&rd=1
Old Oct 14, 2004 | 09:23 AM
twllin's Avatar
Id like to see a write up on this too would make it a lot easier to take my system out like this i think
Old Oct 14, 2004 | 09:25 AM
Progress's Avatar
It's business time.
That looks pretty cool actually. I don't really get the benefits of it yet.
Old Oct 14, 2004 | 09:35 AM
wngan9447's Avatar
Chicken Feet Croo!
Does anyone have a FREE write-up that they can kindly share? I don't want to step on anyones toes, just don't feel like paying someone on ebay when we have the org.
Old Oct 14, 2004 | 09:39 AM
PoLo's Avatar
2-Wheelin it...
what dont' you get about DOOR HINGE. just stare it for 2 seconds...it might click in.
also, how's this make the system come out easier....trunk hole still the same size.
Old Oct 14, 2004 | 09:43 AM
twllin's Avatar
teh angle of the stock lid is hard to get out cuz of the way my box is shaped.........
Old Oct 14, 2004 | 10:33 AM
nailz420's Avatar
I've heard people say it makes your trunk lid rattle. Is that true?
Old Oct 14, 2004 | 10:39 AM
PoLo's Avatar
2-Wheelin it...
that would make sense, as it's just a hinge. the back part of the lid can now essentially flap up and down. not a lot, since the door is "locked" but it's got some space to move now. what you COULD do to remedy that is put some velcro so that when you close it, that may give it some steadiness. the velcro would also let you open it the normal way or the modded way.
Old Oct 14, 2004 | 06:00 PM
Exactly what kind of door hinge, I mean, I don't want to go to Home Depot looking at 32423 door hinges of all different sizes and stuff.
Old Oct 14, 2004 | 08:14 PM
WHEELMAN_03_SE's Avatar
http://www.v6z24.com/howto/fliptrunk, here is a link to an ok write up....
WHEELMAN
Old Oct 15, 2004 | 08:57 AM
nyautostyle's Avatar
I also have a write up, i'll post it on here when i can find it
Old Oct 15, 2004 | 09:10 AM
PoLo's Avatar
2-Wheelin it...
i feel like stabbing someone. that's like a write up on how to fill your gas tank. it's obvious....THIS IS OBVIOUS HOW TO DO IT!!
Old Oct 15, 2004 | 09:12 AM
write up...and its free!!
Materials:
2 - 2" Slide Bolts (Latches)
2 - 3” Strap Hinges
1. Drill with small bit (1/16” to 1/8” depending on the size of the screws) to pre-drill screw holes and a large bit (5/16” or 3/8”) to drill for the latches in Step #6
Phillips screwdriver (the screws should come with the hardware)
2. Attach one side of the hinge to the side of the bracket that was connected to the trunk with the hinge facing away from the trunk. Repeat on the other side. Make sure to pre-drill your holes.
3. With help reconnect the trunk to the brackets using only the bottom bolts (the top ones won’t go in because the hinge is covering the hole for them).
4. With the trunk in place, pre-drill and screw in the screws for the other side of the hinges. You may have to bend the hinges slightly to get them to fit right. A little pressure or a small hammer will do the trick.
5. Connect the latches about 2 inches from the bottom of where the brackets touch the trunk lid. Be sure they are mounted on the inside of the brackets.
6. Mark a spot on the stock bracket to drill a hole to allow the latches to latch (this is where the big drill bit comes in). You may have to remove the bottom bolts to drill so you don’t damage them if you ever want to put it back to stock. Be sure the latches will close tightly. If they don't you may have to replace the bottom bolts each time you want to fold down your trunk lid. (If you don’t plan on using this trick too often, you can skip the latches and just replace the bottom bolt anyway. This will keep it very secure but still let you use it when you really want to.)
7. Once you have the latches on, you can remove the bottom bolts if you haven’t already and flip the trunk down. The hinges will let the trunk fold down to level, but not any farther. To close the trunk flip it up, slide the latches into the holes you drilled in step #6, and close the trunk normally.
8. If you have some subwoofers in the trunk, you might want to put some foam tape along the stock brackets to keep the trunk from rattling against them.
9. If at any time you want to put it back to stock, you can just remove the hardware and replace the bolts. There will only be a few small holes showing.
Donate to my broke *** paypal: agentsc00by@aol.com
Old Jan 6, 2012 | 07:23 AM
ekafrawy's Avatar
Materials:
2 - 3” Strap Hinges
Old Jan 6, 2012 | 11:11 AM
UGAd13's Avatar
Originally Posted by ekafrawy
Old Jan 6, 2012 | 01:07 PM
Rods03Max619's Avatar
7 years plus Damn....
Old Jan 6, 2012 | 03:23 PM
Nexus67's Avatar
I never get tired of these
Old Jan 6, 2012 | 05:15 PM
240sxguy's Avatar
I remember when that was cool... in 2004.. as evidenced by this thread.
Old Jan 6, 2012 | 06:06 PM
T_Behr904's Avatar
Noobs resurrecting a thread from the dead seriously needs to stop...
Old Jan 6, 2012 | 09:25 PM
bocian's Avatar
that double facepalm gets me everytime, hahaha thank you for that
Old Jan 6, 2012 | 10:27 PM
Grand_hustle17's Avatar
I don't mind ppl bringing up old thread cause when they start new ones e are he same ppl telling them to search... this is searching.... working lol......... can't say I've ever wanted to do tht mod though... tarded if u ask me lol
Old Jan 7, 2012 | 06:42 AM
Sneaky Green's Avatar
What is this tranformers 4! Trade your Max in, Get a POS Mercury And get twisting doors and add this trunk mod along with 31" rims and a golden paint job EPIC FAIL!
Old Jan 7, 2012 | 02:47 PM
MintVQ35's Avatar
Before I checked the original post date I was in shock that something like this would still have any sort of following in 2012 lol.
Old Jan 7, 2012 | 04:09 PM
Nexus67's Avatar
True. I think it's not so much the bump more so than it is the WAY it's bumped lol. That's always what gets me goin
A lil gold nevarrr done hurt nobody
Old Jan 9, 2012 | 05:08 PM
SmokedVQ's Avatar
8 years later.................. L M F A O
Old Jan 10, 2012 | 06:38 AM
luvlexus101's Avatar
lololool I just wanted to see who bumped this cause I knew there was no way this was a recent thread.
Old Jan 16, 2012 | 12:21 PM
mr_jon's Avatar
Trex
wow I would love to have that on my car
Old Jan 16, 2012 | 05:11 PM
jaxter09's Avatar
idk about yall but i dont think i ever seen a car with that mod around where i live therefore its going in my maxima lol...as old as this thread is if that person wouldnt of have brought this up i would of have never thought about it! so thank you my friend lol
REDinLV
Aug 15, 2024 12:30 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
