Knocking sound
Old Oct 15, 2004 | 07:13 AM
defcharge's Avatar
Knocking sound
I have a 2002 Max, I noticed this knocking sound on the left side of the car when I am turning right after I make a complete stop and the knocking sound happens when you accelerate into the turn. The slight right does not cause this effect, its only the stop and turn right and accelerate.
Any Help!!!
DefCharge
Old Oct 15, 2004 | 08:02 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
Have you had the recall done to your car ? they repleace the latteral links which would cause your phenomenon. I would check with the dealer and see if the recall is still open on your car- meaning it hasn't been done.
Old Oct 15, 2004 | 08:21 AM
boondoxmax's Avatar
i had a similar problem with my 02. they replaced the front sway bar/bushings and that solved the problem
Old Oct 16, 2004 | 11:07 AM
defcharge's Avatar
Thanks folks. I have an appointment setu for the Recall check, I will also have them look at the sway bar/bushings as well.
Old Oct 18, 2004 | 08:07 AM
murjose's Avatar
Sounds like the same problem I have. I see you are in the DC area. What ever you do, don't bring it to VOB in Rockville up off of the Beltway. Check this out...
http://forums.maxima.org/showthread.php?t=345137
Hope this helps. It helped me.
VOB Sucks
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
