Tool for Rear Brake Piston 03Maxima
What special tool did you guys use to push the piston in for the rear brake piston to replace brake pads?
I used the brake piston tool for the front which pushes the piston in but I know you need a special took for the rear because it doesn't work with the tool used in the front.
What does it look like and where can I get one?
Thank You
Thank You
Thank You
Thank You
That's sick Yeah I think that would work out but I might scratch it up or even strip the edges.
I guess I will have to visit the auto store today to buy that tool and give it a shot again. But you should have seen me taking the front off with the normal brake tool that pushed the piston in without a problem. It took me an hour to do it and thought it was so easy until I looked at the rear brakes. I was not familiar with the piston that is used in the rear. I had a honda before and it was drums in the rear and my other cars I had were not like this as well. This is something new to me.
Thanks for you help
Thanks for you help
yeah, I use a decent pair of needle-nose pliers and gently turn it clockwise... be careful 'cause you don't want to slip and rip the rubber seal around it
be slow and steady with it.
I was not familiar with the piston that is used in the rear. This is something new to me.
Thanks for you help[/QUOTE]
Isn't this weird.... We own great reliable cars... but if you look at the rear breaks we are talking about, breaks from the 280 ZX that started in 1979. I think NIssan is trying to get rid of all the break systems they still have in stock...hehehehe.
