How do i know if my Water pump is goin
Old Oct 19, 2004 | 10:15 PM
v8 killa's Avatar
Hearing a slight grinding style noise from the water pump area
Old Oct 20, 2004 | 08:27 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
How many miles ? listen to it closely. Unless you have good mechanical skills, I would leave the repair up to the dealership. Its hidden way in the engine, requires removal of the timing chain covers. Very big job, at the same time recomend doing all new timing chain tensioners.
Old Oct 20, 2004 | 08:51 AM
Max_Gator's Avatar
As I learned on my 96 recently - look for very small leaks on your garage floor.
That pump will usually start leaking well in advance of dying.
Old Oct 20, 2004 | 09:13 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
If you replace the water pump...go ahead and do all the work.... icluding Timming Chain...............etc....... too expensive..to do it twice
Old Oct 20, 2004 | 11:47 AM
Andrew's Avatar
You can look for leaks but if my memory serves me correct, I had several american cars for a while until I bought my Maxima. When the pump was going, there was a small relief hold that used to have steam or water coming out of it IF the pump was going bad. Usually you can see the hole from the top or you have to get under the car. As for Maxima's, I have not a clue until it does go. Good Luck and let us know what you find out.
Andy
Old Oct 20, 2004 | 11:51 AM
spirilis's Avatar
yeah, the "weephole." We don't have such a thing, but as Max_Gator mentioned above, look for small coolant leaks on the garage floor... that's probably the rough equivalent.
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
