slotted rotor installed? Which directions?
what direction are the slots supposed to be facing? (Images would be BEST!!!) Brembo slotted cross drilled if it makes a difference.
Greg
Greg
You deserve a
http://www.carsandfish.com/carweb/im...tted_Rotor.jpg
Imagine the rotor turning clockwise.
~limsandy
~limsandy
hey if this is your driver side tire your rotor should face this way. " \ " thats how your slots should face. so that the top of the slot hooks down \ \ \ \ \ when rotating.
driver side wheel.
driver side wheel.
here I found the proper way on a write up.
I guess it does matter
http://www.baer.com/support/TechTips.aspx?TechTipID=2
The "premature fatigue/failure" they're referring to is the fact that air won't pass properly through the center vents if those are installed the wrong direction. Therefore, they will not receive proper cooling and will overheat.
Originally Posted by scopium
um actuall if u install it the other way around is better on the pads .. cleans it better
it says it gathers up heat that way. plus my wheels don't get dirty with these slotted rotors. I use to get more dust with the OEM'S.
Originally Posted by soundmike
My PowerSlots specifically mention which rotor goes on which side.
Here's a shot of the rear driver side wheel i took recently.
On the other hand, the other way around would cause pad material to migrate to the center, where it would be flung back out by centripetal force.
Ahhh wait I have Powerslots too in the front and mine goes the other way.....\\\\\ not//// , so am I wrong or what. If so I have riding on those for monts now..... Should I re do them?
nah, leave them thats the right way according to the site.
j/k
