SES Codes....
SES Codes....
Sorry for the newb question.... I searched but can't find anything . . . (been a long day) . . .
Do you guys have a list of what the codes mean?
I have a friend that is having problems with his 2000 maxima & he's coming to my house on saturday... i'll get the codes pulled @ autozone but I don't know what they mean.....
Any help is appreciated...
Here is a list of the error codes for the 5th Generation Maxima (USA) and their descriptions:
P0011 - IVT Control (Bank 1)
P0021 - IVT Control (Bank 2)
P0031 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 1)
P0032 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 2)
P0037 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 1)
P0038 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 2)
P0051 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 1)
P0052 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 2)
P0057 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 1)
P0058 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 2)
P0100 - Mass Air Flow Sensor
P0101 - Mass Air Flow Sensor Circuit Range / Performance Problem
P0102 - Mass Air Flow Sensor Circuit Low Input
P0103 - Mass Air Flow Sensor Circuit High Input
P0105 - Absolute Pressure Sensor
P0107 - Absolute Pressor Sensor Circuit Low Input
P0108 - Absolute Pressor Sensor High Input
P0110 - Intake Air Temperature Sensor
P0112 - Intake Air Temperature Sensor Circuit Low Input
P0113 - Intake Air Temperature Sensor Circuit High Input
P0115 - Engine Coolant Temperature Sensor Circuit
P0117 - Engine Coolant Temperature Sensor Circuit Low Input
P0118 - Engine Coolant Temperature Sensor Circuit High Input
P0120 - Throttle Position Sensor
P0122 - Throttle Position Sensor 2 Circuit Low Input
P0123 - Throttle Position Sensor 2 Circuit High Input
P0125 - Insufficient Engine Coolant Temperature For Closed Loop Fuel Control
P0127 - Intake Air Temperature Too High
P0128 - Thermostat Malfunction
P0130 - Front O2 Sensor Circuit (Bank 1)
P0131 - Front O2 Sensor (Lean) (Bank 1)
P0132 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 1)
P0133 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 1)
P0134 - (2000-2001) Front O2 Sensor High Input (Bank 1)
P0134 - (2002-2003) Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 1)
P0135 - Front O2 Sensor Heater (Bank 1)
P0137 - Rear O2 Sensor Low Input (Bank 1)
P0138 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1)
P0139 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 1)
P0140 - Rear O2 Sensor High Input (Bank 1)
P0141 - Rear O2 Sensor Heater (Bank 1)
P0150 - Front O2 Sensor Circuit (Bank 2)
P0151 - Front O2 Sensor (Lean) (Bank 2)
P0152 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 2)
P0153 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 2)
P0154 - (2000-2001) Front O2 Sensor High Input (Bank 2)
P0154 - (2002-2003) Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 2)
P0155 - Front O2 Sensor Heater (Bank 2)
P0157 - Rear O2 Sensor Low Input (Bank 2)
P0158 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 2)
P0159 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 2)
P0160 - Rear O2 Sensor High Input (Bank 2)
P0161 - Rear O2 Sensor Heater (Bank 2)
P0171 - Fuel Injection System Too Lean (Bank 1)
P0172 - Fuel Injection System Too Rich (Bank 1)
P0174 - Fuel Injection System Too Lean (Bank 2)
P0175 - Fuel Injection System Too Rich (Bank 2)
P0180 - Fuel Tank Temperature Sensor
P0181 - Fuel Tank Temperature Sensor Circuit Range / Performance
P0182 - Fuel Tank Temperature Sensor Low Input
P0183 - Fuel Tank Temperature Sensor High Input
P0217 - Coolant Over Temperature Enrichment Protection
P0221 - Throttle Position Sensor Circuit Range / Performance Problem
P0222 - Throttle Position Sensor 1 Circuit Low Input
P0223 - Throttle Position Sensor 1 Circuit High Input
P0226 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
P0227 - Accelerator Pedal Position Sensor 1 Circuit Low Input
P0228 - Accelerator Pedal Position Sensor 1 Circuit High Input
P0300 - Multiple Cylinder Misfire Detected
P0301 - Cylinder 1 Misfired Detected
P0302 - Cylinder 2 Misfired Detected
P0303 - Cylinder 3 Misfired Detected
P0304 - Cylinder 4 Misfired Detected
P0305 - Cylinder 5 Misfired Detected
P0306 - Cylinder 6 Misfired Detected
P0325 - Knock Sensor
P0327 - Knock Sensor Circuit Low Input
P0328 - Knock Sensor Circuit High Input
P0335 - Crankshaft Position Sensor Circuit
P0340 - Camshaft Position Sensor (Phase) Circuit (Bank 1)
P0345 - Camshaft Position Sensor (Phase) Circuit (Bank 2)
P0400 - EGR Function (Close)
P0403 - EGR Volume Control Valve Circuit
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
P0440 - EVAP Control System Small Leak
P0441 - EVAP Control System Incorrect Purge Flow
P0442 - EVAP Control System Small Leak Detected (Negative Pressure)
P0443 - EVAP Canister Purge Volume Control Solenoid Valve Circuit
P0444 - EVAP Canister Purge Volume Control Solenoid Valve Circuit Open
P0445 - EVAP Canister Purge Volume Control Solenoid Valve Circuit Shorted
P0446 - EVAP Canister Vent Control Valve Circuit
P0447 - EVAP Canister Vent Control Valve Circuit Open
P0450 - EVAP Control System Pressure Sensor
P0452 - EVAP Control System Pressure Sensor Low Input
P0453 - EVAP Control System Pressure Sensor High Input
P0455 - EVAP Control System Gross Leak
P0456 - EVAP Emission Control System Very Small Leak (Negative Pressure Check)
P0460 - Fuel Level Sensor Circuit Noise
P0461 - Fuel Level Sensor Circuit Range / Performance
P0462 - Fuel Level Sensor Circuit Low Input
P0463 - Fuel Level Sensor Circuit High Input
P0464 - Fuel Level Sensor Circuit
P0500 - Vehicle Speed Sensor
P0505 - Idle Air Control Valve / Auxiliary Air Control Valve
P0506 - Idle Speed Control System RPM Lower Than Expected
P0507 - Idle Speed Control System RPM Higher Than Expected
P0510 - Closed Throttle Position Switch
P0550 - Power Steering Pressure Sensor Circuit
P0600 - A/T Communication Line
P0605 - Engine Control Module (ECM)
P0650 - Malfunction Indicator (MIL) Control Circuit
P1065 - ECM Power Supply Circuit
P1102 - Mass Air Flow Sensor Circuit Range / Performance Problem
P1121 - Electric Throttle Control Actuator
P1121 - ABS / TCS Control Unit Performance
P1122 - Electric Throttle Control Performance Problem
P1124 - Throttle Control Motor Relay Circuit Short
P1126 - (2000-2001) Thermostat Function
P1126 - (2002-2003) Throttle Control Motor Relay Circuit Open
P1128 - Throttle Control Motor Relay Circuit Short
P1130 - Swirl Control Valve Control Solenoid Valve
P1143 - Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 1)
P1144 - Heated Oxygen Sensor 1 Rich Shift Monitoring (Bank 1)
P1146 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 1)
P1147 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 1)
P1148 - Closed Loop Control (Bank 1)
P1163 - Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 2)
P1164 - Heated Oxygen Sensor 1 Rich Shift Monitoring (Bank 2)
P1165 - Swirl Control Valve Control Vacuum Check Switch
P1166 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 2)
P1167 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 2)
P1168 - Closed Loop Control (Bank 2)
P1211 - ABS/TCS Control Unit
P1212 - ABS / TCS Communication Line
P1217 - Engine Over Temperature
P1223 - Throttle Position Sensor 2 Circuit Low Input
P1224 - Throttle Position Sensor 2 Circuit High Input
P1225 - Closed Throttle Position Learning Performance Problem
P1226 - Closed Throttle Position Learning Performance Problem
P1227 - Accelerator Pedal Position Sensor 2 Circuit Low Input
P1228 - Accelerator Pedal Position Sensor 2 Circuit High Input
P1229 - Sensor Power Supply Circuit Short
P1320 - Ignition Signal
P1335 - Crankshaft Position Sensor (REF)
P1336 - Crankshaft Position Sensor (POS) (COG)
P1401 - EGR Temperature Sensor
P1402 - EGR Function (Open)
P1440 - EVAP Control System Small Leak
P1444 - EVAP Canister Purge Volume Control Solenoid Valve
P1446 - EVAP Canister Vent Control Valve Closed
P1447 - EVAP Emission Control System Purge Flow Monitoring
P1448 - EVAP Canister Vent Control Valve Open
P1456 - EVAP Emission Control System Very Small Leak (Positive Pressure Check)
P1464 - Fuel Level Sensor Circuit Ground Signal
P1490 - Vacuum Cut Valve Bypass Valve Circuit
P1491 - Vacuum Cut Valve Bypass Valve Circuit
P1564 - Automatic Speed Control Device Steering Switch
P1572 - Automatic Speed Control Device Brake Switch
P1574 - Automatic Speed Control Device Vehicle Speed Sensor
P1605 - A/T Diagnosis Communication Line
P1706 - Park / Neutral Position Switch
P1800 - VIAS Control Solenoid Valve Circuit Open
P1805 - Brake Switch
P2122 - Accelerator Pedal Position Sensor 1 Circuit Low Input
P2123 - Accelerator Pedal Position Sensor 1 Circuit High Input
P2127 - Accelerator Pedal Position Sensor 2 Circuit Low Input
P2128 - Accelerator Pedal Position Sensor 2 Circuit High Input
P2135 - Throttle Position Sensor Circuit Range / Performance Problem
P2138 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
U1000 - CAN Communication Line
U1001 - CAN Communication Line
Originally Posted by soonerfan
you are welcome.
you see that everyone who says i have nothin better to do then to flame people and "be mean"
outacash, FAQ is your friend.
Originally Posted by CCS2k1Max
No such luck. Credit should go to studman for his post in the FAQ-U thread.
i searched the FAQ as much as i could *(not a newbie)* hard to search while at work with boss behind the back...
i didn't find it in the table of contents.... and it's on post# 100
thanks again though.
Sam
sorry to butt in the thread..i have codes 1320 and 0301 come up...are the two interrelated? should i just change cylinder 1 ignition coil or replace all 6?? just wanted some input before i changed stuff around..thanks in advance..NO ONES been responding last couple days in my other posts...
spencerwh1
Jun 30, 2016 05:44 AM
yat70458
Aug 3, 2015 01:16 PM
Wills98MaxSE
Jul 27, 2002 05:41 PM
