wheel bearings covered under the 60k powertrain?
Old Oct 21, 2004 | 01:41 PM
mastah's Avatar
Does anyone have evidence that the wheel bearings are covered under the 60k powertrain coverage? Thanks in advance.
Old Oct 21, 2004 | 02:05 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if you consider evidence that i just had my passenger side replaced last week under 60k powertrain then you are set. i have an extended warranty but they said it was not needed since i only had 51k. i actually drove over 200 miles since nissan said they could not tow until failure, lucky for me and them that the hub was fine.
Old Oct 21, 2004 | 03:49 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
Technically, they are not, but Nissan usually replaces them b/c they are well aware that they (the bearings) suck...
Old Oct 22, 2004 | 04:03 PM
irish44j's Avatar
retired moderator
My local dealer told me they were. Unfortunately, I had 62,000 miles so they had to fix them undre my extended warranty instead (with a $50 copay)
Old Oct 22, 2004 | 04:40 PM
spirilis's Avatar
Your wheel bearings did go bad? (thought it was only a bent wheel)
Old Oct 22, 2004 | 05:43 PM
Trance Artur's Avatar
How do you know if you wheel bearings are bad?
Old Oct 22, 2004 | 05:53 PM
maximadave's Avatar
detailerdaveb@gmail.com
no problems here on wheel bearings. I have 68K miles. Knock on wood. Curious on what to look for....
Old Oct 23, 2004 | 07:02 PM
Hey guys, how do you know if you wheel bearings are bad?
Old Oct 23, 2004 | 07:20 PM
SoonerFan's Avatar
Cletus
it isnt very clear. "bearings" is under drivetrain...but there are alot of bearings in the drivetrain.
http://www.nissanusa.com/content/0,,sctid-51124,00.html
POWERTRAIN COVERAGE
• The Powertrain coverage period is 60 months or 60,000
miles, whichever comes first.
• This warranty covers any repairs needed to correct
defects in materials or workmanship.
• Powertrain coverage applies to components listed below,
supplied by Nissan except for those items listed
under the caption “WHAT IS NOT COVERED”.
ENGINE
Cylinder heads and block and all internal parts, rocker
covers and oil pan, valve train and front cover, timing chain
and tensioner, oil pump, water pump and fuel pump, fuel
injectors, intake and exhaust manifolds and supercharger,
flywheel, seals, and gaskets.
TRANSMISSION AND TRANSAXLE
Case and all internal parts, torque converter and converter
housing, automatic transmission control module, transfer
case and all internal parts, seals and gaskets, clutch cover
and housing, and electronic transmission controls.
DRIVETRAIN
Drive shafts, final drive housing and all internal parts,
propeller shafts, universal joints, bearings, seals and gaskets.
bbsitum
Sep 6, 2019 07:31 PM
Jay556
Sep 12, 2015 05:50 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
maximusrising
Sep 2, 2015 09:55 AM
